Данный сайт является проектом ООО "Амакс". Сегодня: Понедельник, 20.05.2024, 02:50
Неофициальный форум технической поддержки Hikvision » Оборудование и программное обеспечение Hikvision » DVR - цифровые видеорегистраторы Hikvision » Hikvision DS-7204 settings for slow upload connection
ased13Дата: Среда, 19.09.2012, 22:31 | Сообщение # 1
Hello,
I have bought the DS-7204 Series DVR. I have installed it with 3 cameras on it. I am interested in watching live streaming via the internet. My upload is quite low thought at 512kbps. Can you tell me what are the recommended resolution,frame rate, bit rate and other parameters of output bitstream for my internet connection?
Thank you
AlexandrДата: Четверг, 20.09.2012, 11:21 | Сообщение # 2
write please accurate name of your DVR (eg DS-7204HVI-S or DS-7204HFI-ST, etc.). Different models have the different settings.
You can configure an additional sub-stream for the link and connect to this sub-stream. Sub-stream services for this purpose.
to approximate the flow, you can use the table:
example for the four cameras while watching:
512-20%(service traffic)=409,6\4=102,4
select from a table close to the calculated values:
Прикрепления: 1237383.jpg (71.5 Kb) · 6295659.jpg (72.3 Kb)
ased13Дата: Четверг, 20.09.2012, 15:05 | Сообщение # 3
Thanks for the quick reply.
The model is DS-7200HVI-ST. I have make the following settings at the VIdeo Parameters tab :
Encoding Parameters : Substream
Stream Type : Video
Resolution : CIF
Bitrate Type : Constant
Bitrate : 128kbps
Frame rate : 6
Video Quality : HIgh [DONT have a choice there its autoselected]
Frame Type : Single P Frame
I Frame Interval :100
Should I change anything?
Thank you
AlexandrДата: Четверг, 20.09.2012, 18:13 | Сообщение # 4
To begin, I would like:
Bitrate Type : variable
Bitrate : 96kbps
Frame rate : 1
if you set "Bitrate Type : variable" than you can change "Video Quality :" to highest.
if those settings will be transferred to the image well, you can improve the bitrate and framerate.
