7616NI-SE На старте ошибка CRC
hagark | Дата: Вторник, 04.08.2015, 07:08 | Сообщение # 1 |
| Пациент 7616NI-SE ребут по кругу. На старте ошибка CRC. Перешил на свежую прошивку, эффект тот же, просто ERR меньше стало. Менять флэшку? Код U-Boot 2010.06 (May 22 2013 - 03:06:14)
env_relocate_spec:*** Warning - bad CRC, using default environment
Hit ctrl+u to stop autoboot: 0
Starting kernel ...
Uncompressing Linux... done, booting the kernel. Starting udev: [ OK ] mount jffs2 filesystem done. MemTotal: 124004 kB MemFree: 114444 kB Buffers: 40 kB Cached: 932 kB SwapCached: 0 kB Active: 824 kB Inactive: 512 kB Active(anon): 364 kB Inactive(anon): 4 kB Active(file): 460 kB Inactive(file): 508 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 12 kB Writeback: 0 kB AnonPages: 392 kB Mapped: 360 kB Shmem: 4 kB Slab: 2236 kB SReclaimable: 728 kB SUnreclaim: 1508 kB KernelStack: 320 kB PageTables: 80 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 111600 kB Committed_AS: 3760 kB VmallocTotal: 696320 kB VmallocUsed: 576 kB VmallocChunk: 691456 kB show logo Mon Aug 3 13:10:46 UTC 2015 start decompress Mon Aug 3 13:11:11 UTC 2015 start run binary Mon Aug 3 13:11:11 UTC 2015 iSCSI daemon with pid=126 started!BusyBox v1.2.1 Protect Shell (psh) Enter 'help' for a list of davinci system commands.
# g_cpldinfo->magic 0x43504c44 g_cpldinfo->pcb_type 0x8109 g_cpldinfo->arm_freq 0x1 g_cpldinfo->panel_type 0x1 g_cpldinfo->rs232_count 0x1 g_cpldinfo->rs485_count 0x1 g_cpldinfo->usb_count 0x2 g_cpldinfo->alarm_out 0x1 g_cpldinfo->alarm_in 0x1 alarm panel not found. devHardInfo.alarmInNums = 0 devHardInfo.alarmOutNums = 0 devHardInfo.ataCtrlNums = 0 devHardInfo.decodeChans = 16 devHardInfo.dspSoftwareBuildDate = 0x0 devHardInfo.dspSoftwareVersion = 0x0 devHardInfo.encodeChans = 0 devHardInfo.hardwareVersion = 0x400 devHardInfo.networkNums = 1 devHardInfo.panelVersion = 0 devHardInfo.ramSize = 1024 devHardInfo.softwareBuildDate = 0x0 devHardInfo.softwareVersion = 0x0 devModel = DS-7616NI-SE prodNo = 428420586 magicNumber = 1212897107 voNums = 2 ipcChans = 0 paraChecksum = 2481 paraLength = 244 language = 1 device_class = 16 oemCode = 1 encodeChans = 0 decodeChans = 16 picFormat = 2 devHigh = 0 cpuFreq = 2 dspFreq = 2 zone = 3 webSupport = 1 voipSupport = 0 usbNums = 2 lcdSupport = 0 vtSupport = 1 videoMaxtrix = 0 extendedDecoder = 0 extendedIVS = 0 extendedAlarmOut = 0 devType = 0x7b0f ubootAdrs = 0x0 ubootSize = 0 ubootCheckSum = 0 tinyKernelAdrs = 0x0 tinyKernelSize = 0 tinyKernelCheckSum = 0 /*********************init_global_error_lib*/, init_global_error_lib start! [ERR][net/netUtil/net_util.c #1350]: eth0 mac address is: 8c:e7:48:2a:aa:03 Can't open parameter file on flash, errno=0x2. getPPPOECfg: from /home/hik/devCfg.bin ok. bond card eth0 to pppoed ==================enablePPPoE failed!!! IR panel found. [ERR][net/sdkService/netOsd.c #57]: creat /home/app/netOsd.bin OK ! [CRIT][system/param/paramLib.c #6381]: readDevParam from /home/hik/devCfg.bin OK
paraVersion:150326 end type:2 [CRIT][system/param/paramLib.c #6394]: cfg is ok, but sys cfg no patched sizeof(NETRA_DSP_INIT_PARAM) = 1055876 encChanNums=0, flgEncChanEnable=0x0, chipRev = 33031 g_pDspInitPara->decChanCnt=16 g_pDspInitPara->ipcChanCnt=16, flgIpcChanEnable=0x406b30000000ffff video_AD = 1 <lib>-----InitDioMemHeap,cnt 21 phyAddr=0x82400000,virtaddr 0x44a11000,vaddr=0x4 4a11000,size=0x5000000------ --------->>>>>>>>>> pid is 132 TSK_processHostCmd --------->>>>>>>>>> pid is 133 TSK_DispatchAo arg 0 --------->>>>>>>>>> pid is 134 TSK_ProcessAi --------->>>>>>>>>> pid is 135 TSK_DispatchHdmiAo --------->>>>>>>>>> pid is 136 TSK_ProcessAudioTalkBack --------->>>>>>>>>> pid is 137 TSK_StreamPackProcess --------->>>>>>>>>> pid is 138 TSK_GetJpegData --------->>>>>>>>>> pid is 139 TSK_DspQueueService --------->>>>>>>>>>TSK_Decode pid is 140 chan 0 --------->>>>>>>>>>TSK_Decode pid is 141 chan 1 --------->>>>>>>>>>TSK_Decode pid is 142 chan 2 --------->>>>>>>>>>TSK_Decode pid is 143 chan 3 --------->>>>>>>>>>TSK_Decode pid is 144 chan 4 --------->>>>>>>>>>TSK_Decode pid is 145 chan 5 --------->>>>>>>>>>TSK_Decode pid is 146 chan 6 --------->>>>>>>>>>TSK_Decode pid is 147 chan 7 --------->>>>>>>>>>TSK_Decode pid is 148 chan 8 --------->>>>>>>>>>TSK_Decode pid is 149 chan 9 --------->>>>>>>>>>TSK_Decode pid is 150 chan 10 --------->>>>>>>>>>TSK_Decode pid is 151 chan 11 --------->>>>>>>>>>TSK_Decode pid is 152 chan 12 --------->>>>>>>>>>TSK_Decode pid is 153 chan 13 --------->>>>>>>>>>TSK_Decode pid is 154 chan 14 --------->>>>>>>>>>TSK_Decode pid is 155 chan 15 --------->>>>>>>>>> pid is 156 TSK_ProcessIpcStream arg 16 --------->>>>>>>>>> pid is 157 TSK_ProcessIpcStream arg 32 --------->>>>>>>>>> pid is 158 TSK_ProcessIpcStream arg 17 --------->>>>>>>>>> pid is 159 TSK_ProcessIpcStream arg 33 --------->>>>>>>>>> pid is 160 TSK_ProcessIpcStream arg 18 --------->>>>>>>>>> pid is 161 TSK_ProcessIpcStream arg 34 --------->>>>>>>>>> pid is 162 TSK_ProcessIpcStream arg 19 --------->>>>>>>>>> pid is 163 TSK_ProcessIpcStream arg 35 --------->>>>>>>>>> pid is 164 TSK_ProcessIpcStream arg 20 --------->>>>>>>>>> pid is 165 TSK_ProcessIpcStream arg 36 --------->>>>>>>>>> pid is 166 TSK_ProcessIpcStream arg 21 --------->>>>>>>>>> pid is 167 TSK_ProcessIpcStream arg 37 --------->>>>>>>>>> pid is 168 TSK_ProcessIpcStream arg 22 --------->>>>>>>>>> pid is 169 TSK_ProcessIpcStream arg 38 --------->>>>>>>>>> pid is 170 TSK_ProcessIpcStream arg 23 --------->>>>>>>>>> pid is 171 TSK_ProcessIpcStream arg 39 --------->>>>>>>>>> pid is 172 TSK_ProcessIpcStream arg 24 --------->>>>>>>>>> pid is 173 TSK_ProcessIpcStream arg 40 --------->>>>>>>>>> pid is 174 TSK_ProcessIpcStream arg 25 --------->>>>>>>>>> pid is 175 TSK_ProcessIpcStream arg 41 --------->>>>>>>>>> pid is 176 TSK_ProcessIpcStream arg 26 --------->>>>>>>>>> pid is 177 TSK_ProcessIpcStream arg 42 --------->>>>>>>>>> pid is 178 TSK_ProcessIpcStream arg 27 --------->>>>>>>>>> pid is 179 TSK_ProcessIpcStream arg 43 --------->>>>>>>>>> pid is 180 TSK_ProcessIpcStream arg 28 --------->>>>>>>>>> pid is 181 TSK_ProcessIpcStream arg 44 --------->>>>>>>>>> pid is 182 TSK_ProcessIpcStream arg 29 --------->>>>>>>>>> pid is 183 TSK_ProcessIpcStream arg 45 --------->>>>>>>>>> pid is 184 TSK_ProcessIpcStream arg 30 --------->>>>>>>>>> pid is 185 TSK_ProcessIpcStream arg 46 --------->>>>>>>>>> pid is 186 TSK_ProcessIpcStream arg 31 --------->>>>>>>>>> pid is 187 TSK_ProcessIpcStream arg 47 --------->>>>>>>>>> pid is 188 TSK_DownloadIpcStream arg 0 --------->>>>>>>>>> pid is 189 TSK_DownloadIpcStream arg 1 --------->>>>>>>>>> pid is 190 TSK_DecJpeg --------->>>>>>>>>> pid is 191 TSK_DecodeReverse --------->>>>>>>>>>TSK_OutputDecVideo pid is 192 chan 0 --------->>>>>>>>>>TSK_OutputDecVideo pid is 193 chan 1 --------->>>>>>>>>>TSK_OutputDecVideo pid is 194 chan 2 --------->>>>>>>>>>TSK_OutputDecVideo pid is 195 chan 3 --------->>>>>>>>>>TSK_OutputDecVideo pid is 196 chan 4 --------->>>>>>>>>>TSK_OutputDecVideo pid is 197 chan 5 --------->>>>>>>>>>TSK_OutputDecVideo pid is 198 chan 6 --------->>>>>>>>>>TSK_OutputDecVideo pid is 199 chan 7 --------->>>>>>>>>>TSK_OutputDecVideo pid is 200 chan 8 --------->>>>>>>>>>TSK_OutputDecVideo pid is 201 chan 9 --------->>>>>>>>>>TSK_OutputDecVideo pid is 202 chan 10 --------->>>>>>>>>>TSK_OutputDecVideo pid is 203 chan 11 --------->>>>>>>>>>TSK_OutputDecVideo pid is 204 chan 12 --------->>>>>>>>>>TSK_OutputDecVideo pid is 205 chan 13 --------->>>>>>>>>>TSK_OutputDecVideo pid is 206 chan 14 --------->>>>>>>>>>TSK_OutputDecVideo pid is 207 chan 15 --------->>>>>>>>>>TSK_OutputDecVideo pid is 208 chan 16 --------->>>>>>>>>>TSK_OutputDecVideo pid is 209 chan 17 --------->>>>>>>>>>TSK_OutputDecVideo pid is 210 chan 18 --------->>>>>>>>>>TSK_OutputDecVideo pid is 211 chan 19 --------->>>>>>>>>>TSK_OutputDecVideo pid is 212 chan 20 --------->>>>>>>>>>TSK_OutputDecVideo pid is 213 chan 21 --------->>>>>>>>>>TSK_OutputDecVideo pid is 214 chan 22 --------->>>>>>>>>>TSK_OutputDecVideo pid is 215 chan 23 --------->>>>>>>>>>TSK_OutputDecVideo pid is 216 chan 24 --------->>>>>>>>>>TSK_OutputDecVideo pid is 217 chan 25 --------->>>>>>>>>>TSK_OutputDecVideo pid is 218 chan 26 --------->>>>>>>>>>TSK_OutputDecVideo pid is 219 chan 27 --------->>>>>>>>>>TSK_OutputDecVideo pid is 220 chan 28 --------->>>>>>>>>>TSK_OutputDecVideo pid is 221 chan 29 --------->>>>>>>>>>TSK_OutputDecVideo pid is 222 chan 30 --------->>>>>>>>>>TSK_OutputDecVideo pid is 223 chan 31 --------->>>>>>>>>>TSK_OutputDecVideo pid is 224 chan 32 --------->>>>>>>>>>TSK_OutputDecVideo pid is 225 chan 33 --------->>>>>>>>>>TSK_OutputDecVideo pid is 226 chan 34 --------->>>>>>>>>>TSK_OutputDecVideo pid is 227 chan 35 --------->>>>>>>>>>TSK_OutputDecVideo pid is 228 chan 36 --------->>>>>>>>>>TSK_OutputDecVideo pid is 229 chan 37 --------->>>>>>>>>>TSK_OutputDecVideo pid is 230 chan 38 --------->>>>>>>>>>TSK_OutputDecVideo pid is 231 chan 39 --------->>>>>>>>>>TSK_OutputDecVideo pid is 232 chan 40 --------->>>>>>>>>>TSK_OutputDecVideo pid is 233 chan 41 --------->>>>>>>>>>TSK_OutputDecVideo pid is 234 chan 42 --------->>>>>>>>>>TSK_OutputDecVideo pid is 235 chan 43 --------->>>>>>>>>>TSK_OutputDecVideo pid is 236 chan 44 --------->>>>>>>>>>TSK_OutputDecVideo pid is 237 chan 45 --------->>>>>>>>>>TSK_OutputDecVideo pid is 238 chan 46 --------->>>>>>>>>>TSK_OutputDecVideo pid is 239 chan 47 --------->>>>>>>>>> pid is 244 Tsk_InitAudio --------->>>>>>>>>> pid is 240 TSK_DownloadStream --------->>>>>>>>>> pid is 245 TSK_OutputDecAudio --------->>>>>>>>>> pid is 242 TSK_ProcessShipin7PlaybackStream arg 0 --------->>>>>>>>>> pid is 243 TskDownloadJpegStream --------->>>>>>>>>> pid is 247 TSK_Init -----------------start open isp----------- -----------------set RM_ISP_RSTCTRL----------- -----------------set CM_ISS_CLKSTCTR----------- -----------------wait CM_ISS_ISP_CLKCTRL 0x20----------- -----------------wait CM_ISS_FDIF_CLKCTRL 0x24----------- <A8_Audio>:HDMI ao buf alloc success! A8 buildTime : 2014-08-28 11:38:58 VID buildTime : 2014-09-06 21:58:11 VPS buildTime : 2014-08-28 17:42:47 play dec chan pVirtAddr[0] = 0x48a21000 play dec chan pVirtAddr[1] = 0x48ab1000 play dec chan pVirtAddr[2] = 0x48b41000 play dec chan pVirtAddr[3] = 0x48bd1000 play dec chan pVirtAddr[4] = 0x48c61000 play dec chan pVirtAddr[5] = 0x48cf1000 play dec chan pVirtAddr[6] = 0x48d81000 play dec chan pVirtAddr[7] = 0x48e11000 play dec chan pVirtAddr[8] = 0x48ea1000 play dec chan pVirtAddr[9] = 0x48f31000 play dec chan pVirtAddr[10] = 0x48fc1000 play dec chan pVirtAddr[11] = 0x49051000 play dec chan pVirtAddr[12] = 0x490e1000 play dec chan pVirtAddr[13] = 0x49171000 play dec chan pVirtAddr[14] = 0x49201000 play dec chan pVirtAddr[15] = 0x49291000 ipc dec chan main stream pVirtAddr[16] = 0x5628f500 ipc dec chan sub stream pVirtAddr[32] = 0x58479500 ipc dec chan main stream pVirtAddr[17] = 0x564adf00 ipc dec chan sub stream pVirtAddr[33] = 0x585d7f00 ipc dec chan main stream pVirtAddr[18] = 0x566cc900 ipc dec chan sub stream pVirtAddr[34] = 0x58736900 ipc dec chan main stream pVirtAddr[19] = 0x568eb300 ipc dec chan sub stream pVirtAddr[35] = 0x58895300 ipc dec chan main stream pVirtAddr[20] = 0x56b09d00 ipc dec chan sub stream pVirtAddr[36] = 0x589f3d00 ipc dec chan main stream pVirtAddr[21] = 0x56d28700 ipc dec chan sub stream pVirtAddr[37] = 0x58b52700 ipc dec chan main stream pVirtAddr[22] = 0x56f47100 ipc dec chan sub stream pVirtAddr[38] = 0x58cb1100 ipc dec chan main stream pVirtAddr[23] = 0x57165b00 ipc dec chan sub stream pVirtAddr[39] = 0x58e0fb00 ipc dec chan main stream pVirtAddr[24] = 0x57384500 ipc dec chan sub stream pVirtAddr[40] = 0x58f6e500 ipc dec chan main stream pVirtAddr[25] = 0x575a2f00 ipc dec chan sub stream pVirtAddr[41] = 0x590ccf00 ipc dec chan main stream pVirtAddr[26] = 0x577c1900 ipc dec chan sub stream pVirtAddr[42] = 0x5922b900 ipc dec chan main stream pVirtAddr[27] = 0x579e0300 ipc dec chan sub stream pVirtAddr[43] = 0x5938a300 ipc dec chan main stream pVirtAddr[28] = 0x57bfed00 ipc dec chan sub stream pVirtAddr[44] = 0x594e8d00 ipc dec chan main stream pVirtAddr[29] = 0x57e1d700 ipc dec chan sub stream pVirtAddr[45] = 0x59647700 ipc dec chan main stream pVirtAddr[30] = 0x5803c100 ipc dec chan sub stream pVirtAddr[46] = 0x597a6100 ipc dec chan main stream pVirtAddr[31] = 0x5825ab00 ipc dec chan sub stream pVirtAddr[47] = 0x59904b00 111###menu: i[0], phy:0x0, vir:0x0, w=0,h=0,pitch=0 111###menu: i[1], phy:0xb0400000, vir:0x4c787000, w=1920,h=1200,pitch=7680 DSP START OK Cannot get current device settings: Operation not supported init_stor_system maxEnChanNo = 0 maxIPCount 16 [ERR][socket/socket_base.cpp #92]: can't get host by name dev.ezviz7.com [ERR][protocol/control.cpp #534]: the das server is not valid [ERR][socket/socket_base.cpp #92]: can't get host by name dev.ezviz7.com [CRIT][system/init/dvr.c #2154]: upgrade file path is [/home/hik/] [CRIT][system/init/dvr.c #2169]: upgrade file is correct, the device can start [ERR][net/ipc/ipcService/ipcamera.c #17998]: ipcRepeatConnectTask: start connect ipc time = 1438607478 [ERR][net/ipc/ipcService/sadpSvc/sadpService.c #2110]: sadp_get_uuid[4ffc8703-88 0c-4376-b396-eceac2c30b20] [ERR][dataApplication/preview/preview_schedule.c #868]: prev_open_current_screen iChanNum = 0 [ERR][dataApplication/preview/preview_schedule.c #868]: prev_open_current_screen iChanNum = 0 [ERR][dataApplication/preview/preview_schedule.c #3597]: ret=-1 error! iVoChan is not valid [ERR][dataApplication/streamReceive/streamRecv.c #3193]: motDetailLinePtr:0x2b23 658, size=1216(76 x 16) g_sadpInst.ifName[0]=eth0 g_sadpInst.ifName[1]=eth1 iLen [-1], xmlReq.currlen[922] [ERR][spare/spare_nvr_server.c #1680]: the device type is 2 [ERR][spare/spare_nvr_client.c #1578]: the device not support backup. <lib>cmd return err!!!!!cmd =14, E3_INVALID_CHAN [ERR][interface/dsp/dm_cmd_if.c #380]: ###########send_to_dm740, ret=537075714,c mdIdx=114 +++++++++++++++++++First save_error_no, time_t:1438607435 <lib>cmd return err!!!!!cmd =62, E3_INVALID_CHAN [ERR][interface/dsp/dm_cmd_if.c #380]: ###########send_to_dm740, ret=537075714,c mdIdx=162 [ERR][interface/dsp/dm_cmd_if.c #8893]: setMouse [PSWD][0061]:public_base64_len 188 len 140 [CRIT][kernel/init.c #3646]: End of InitGUI!! Device Is Ready
Сообщение отредактировал hagark - Вторник, 04.08.2015, 07:10 |
Alexandr | Дата: Вторник, 04.08.2015, 18:16 | Сообщение # 2 |
| ctrl+u и глянуть доступные команды, может есть форматирование памяти. а уже потом залить прошивку . пс - может и тест памяти есть.
hagark | Дата: Вторник, 04.08.2015, 19:17 | Сообщение # 3 |
| по ctrl+U только автоматом прошивка.
Alexandr | Дата: Вторник, 04.08.2015, 19:33 | Сообщение # 4 |
| скрин сделайте.
hagark | Дата: Вторник, 04.08.2015, 19:47 | Сообщение # 5 |
Alexandr | Дата: Вторник, 04.08.2015, 19:56 | Сообщение # 6 |
| "?" или "h" без кавычек попробуйте. непонятно - [CRIT][system/param/paramLib.c #6394]: cfg is ok, but sys cfg no patched что за прошивки были, ставились ? регистратор случаем не из Китая ? в смысле региональной защиты.
hagark | Дата: Вторник, 04.08.2015, 19:58 | Сообщение # 7 |
| пробовал всё, повторное предложение нажать U.
Alexandr | Дата: Вторник, 04.08.2015, 20:02 | Сообщение # 8 |
| выше дописал вопросы )
hagark | Дата: Вторник, 04.08.2015, 20:07 | Сообщение # 9 |
Что за прошивка была, не знаю. Шил прошивками с этого сайта. Китайские регистраторы (по небольшому опыту) обычно не зашиваются до конца. Это регистратор зашивается полностью, языки выбираются в настройках.
Сообщение отредактировал hagark - Вторник, 04.08.2015, 20:45 |
Alexandr | Дата: Вторник, 04.08.2015, 21:06 | Сообщение # 10 |
| Цитата hagark ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) Шил прошивками с этого сайта. какими ? ведь не зря спрашиваю, были прецеденты.. серийник в браузере или sadp какой ?
hagark | Дата: Вторник, 04.08.2015, 21:43 | Сообщение # 11 |
| Прошивки шил : 8107_2015.02.03, 8107_2013.05.06, 8107_2014.03.19, 8107_2015.07.27
Сообщение отредактировал hagark - Вторник, 04.08.2015, 21:47 |
Alexandr | Дата: Вторник, 04.08.2015, 22:12 | Сообщение # 12 |
| прошивки нормальные, серийник вроде тоже. раз на вебку зашли, значит какое то время рег работает штатно, можно попробовать обновить через Hikvision Tools с установленными галочками сброса на дефолт всех настроек. загрузчик совсем порезан, поискал по форуму, пример. аналогия очевидная. Цитата 3apa3ka ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) Есть такая лазейка с фтп...вот и был слит рабочий дав0(или дав1, не важно) и залит на не рабочий рег в тот же дав0, рестарт через телнет (лично по другому не пробовала, мне так спокойнее). После рестарта стал не рабочий рег с норм прошивкой 2.3.4 и перестал ребутится, попробовала прошить через веб интерфейс, все прошло отлично. дав1 копировался сам после сброса на дефолт. В принципе таким образом можно апдейтить всё, но зачем оно нужно?) вопрос где взять рабочую платформу 8107 ? )) может потереть вообще всё через ftp и залить заново ? у самого практики в таком ракурсе нет, всё решалось перезаливкой, так что советую наобум )
hagark | Дата: Вторник, 04.08.2015, 22:33 | Сообщение # 13 |
| Доступ по FTP, имя пользователя root, а не admin, без пароля. Это, для чайников, что тереть то? Всё? Стрёмно )).
Сообщение отредактировал hagark - Среда, 05.08.2015, 06:50 |
Alexandr | Дата: Понедельник, 10.08.2015, 11:25 | Сообщение # 14 |
| dav найти, слить на комп для подстраховки и стереть в нём файлы, затем tftp. Цитата Alexandr ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) у самого практики в таком ракурсе нет, всё решалось перезаливкой, так что советую наобум )
hagark | Дата: Понедельник, 17.08.2015, 10:32 | Сообщение # 15 |
| Цитата Alexandr ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) стереть в нём файлы, затем tftp. Не помогло.
Alexandr | Дата: Понедельник, 17.08.2015, 10:59 | Сообщение # 16 |
| логи меняются после стирания ? может ведь и флешка сама "битая".. сдавайте в сервис.
hagark | Дата: Среда, 19.08.2015, 09:02 | Сообщение # 17 |
| Цитата Alexandr ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) логи меняются после стирания ? Всё как и при обычной прошивке. Цитата Alexandr ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) может ведь и флешка сама "битая".. Это и предполагал с самого начала, но как обычно надеялся на "авось" Цитата Alexandr ( ![Ссылка на цитируемый текст](http://s41.ucoz.net/img/fr/ic/10/lastpost.gif) ) сдавайте в сервис. Сервис отказал в гарантийном ремонте, потому сам ковыряю.
Alexandr | Дата: Среда, 19.08.2015, 11:46 | Сообщение # 18 |
| Оф. отказал ? к примеру Питер и послегарантийным ремонтом занимаются, если аппарат не "серый".
hagark | Дата: Среда, 19.08.2015, 12:32 | Сообщение # 19 |
| Я с Украины, у нас несоблюдение гарантийных обязательств практически на каждом шагу.
