Данный сайт является проектом ООО "Амакс". Сегодня: Четверг, 26.12.2024, 14:17
Регистратор после прошивки пищит 15 раз
VladKoДата: Понедельник, 02.04.2018, 20:36 | Сообщение # 1
Прошил регистратор (DS-7604N-E1/4P) не той прошивкой, после ребута он включается коротким сигналом, появляется заставка, и при заставке пищит 15 раз длинными сигналами. Пробовал сейчас прошить через TFTP, но ситуация не изменилась, лог TFTP:
[2018-04-02 22:01:48] TFTP server[192.0.0.128] initialized
[2018-04-02 22:25:10] TFTP server[127.0.0.1] initialized
[2018-04-02 22:26:12] TFTP server[127.0.0.1] initialized
[2018-04-02 22:27:22] Device[192.0.0.64] test tftpserver
[2018-04-02 22:27:22] Connect client[192.0.0.64] success
[2018-04-02 22:27:22] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:27:31] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:28:30] Device[192.0.0.64] test tftpserver
[2018-04-02 22:28:30] Connect client[192.0.0.64] success
[2018-04-02 22:28:30] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:28:40] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:36:21] TFTP server[192.0.0.128] initialized
[2018-04-02 22:36:56] Device[192.0.0.64] test tftpserver
[2018-04-02 22:36:57] Connect client[192.0.0.64] success
[2018-04-02 22:36:57] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:36:58] Resend required
[2018-04-02 22:37:01] Resend required
[2018-04-02 22:37:02] Resend required
[2018-04-02 22:37:03] Resend required
[2018-04-02 22:37:06] Resend required
[2018-04-02 22:37:20] Resend required
[2018-04-02 22:37:23] Resend required
[2018-04-02 22:37:25] Resend required
[2018-04-02 22:37:26] Resend required
[2018-04-02 22:37:31] Resend required
[2018-04-02 22:37:32] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:38:31] Device[192.0.0.64] test tftpserver
[2018-04-02 22:38:31] Connect client[192.0.0.64] success
[2018-04-02 22:38:31] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:38:42] Completed file[C:\tftp\digicap.dav] transmit
Добавлено (02.04.2018, 20:36)
Первоначально испортил все прошивкой NVR_K41_BL_ML_STD_V3.4.96_170921, а после пытаюсь исправить DS-76xx_77xx_86xxNI-Ex 2015.06.16 V3.3.4 build 150616 и DS-76xx_77xx_86xxNI-Ex 2015.05.22 V3.3.2 build 150522
iTuneDVRДата: Вторник, 03.04.2018, 12:37 | Сообщение # 2
Интересно как прошил не той прошивкой? wink
VladKoДата: Вторник, 03.04.2018, 12:48 | Сообщение # 3
iTuneDVR, через web интерфейс зашел на регистратор, выбрал не ту прошивку, и прошил
iTuneDVRДата: Вторник, 03.04.2018, 14:46 | Сообщение # 4
Не той прошивкой не прошить, ни через веб, ни через TFTP wink
В процессе прошивки могло что-то случиться невообразимое, но не той не прошить wink
VladKoДата: Вторник, 03.04.2018, 16:57 | Сообщение # 5
iTuneDVR, DS-7600NI-E1(E2) 7700NI-E4 » V3.4.96 build170921 вот эту залил, и он после заливки стал 15 раз пищать и перезагружаться
iTuneDVRДата: Среда, 04.04.2018, 00:19 | Сообщение # 6
Сколько лет аппарату и какая была вначале?
VladKoДата: Среда, 04.04.2018, 06:53 | Сообщение # 7
iTuneDVR
можно как то определить старую прошивку по наклейке? Продавца с китая уже нет.
Сообщение отредактировал VladKo - Среда, 04.04.2018, 06:55
iTuneDVRДата: Среда, 04.04.2018, 12:38 | Сообщение # 8
Умер что-ли?
С этого надо начинать было, что регистратор чинаец.
Снимай дамп.
Если рег старый был, старой версии, то максимум апгрейда - до 3.3.4.
Если рег был софтово пропатчен, то только поэтому и могла влилась европейская прошивка, но поняв реальное окружение истошно орёт wink
VladKoДата: Среда, 04.04.2018, 19:47 | Сообщение # 9
iTuneDVR, Китаец не умер, магазина его уже нет.
То что чинаец, так я написал в группе китайское все, сорян если не прав.
Подскажите как дамп снять?
п.с. есть конвертер CP2102 если он както может помочь
Добавлено (04.04.2018, 19:45)
Добавлено (04.04.2018, 19:47)
Слева от 3х конденсаторов разъем ttl я так понял, а как понять распиновку?
VladKoДата: Среда, 04.04.2018, 21:04 | Сообщение # 10
1- GRD
2- RXD
3-TXD
4- не используется
Верно?
Добавлено (04.04.2018, 20:03)
Осталось найти дельную инструкцию
Добавлено (04.04.2018, 21:04)
Не дождался я ответов)) Методом догадок подключил все через ttl и программы Putty.
Выкладываю логи:
U-Boot 2010.06-svn (May 26 2014 - 10:36:35)
Hit ctrl+u to stop autoboot:  0
### CRAMFS load complete: 3183432 bytes loaded to 0x80400000
timeout wait for link failed!
PHY not link!
MAC:   C0-56-E3-1B-7D-A7
TFTP server auto connect disabled
## Booting kernel from Legacy Image at 80400000 ...
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
init started: BusyBox v1.16.1 (2016-06-29 13:49:45 CST)
Starting udev:      [ OK ]
Sat Jan  3 00:44:54 UTC 1970
----------<1> tar guir webs ----------
----------<2> show logo ----------
show logo Sat Jan  3 00:45:03 UTC 1970
mv: can't rename '/home/app/exec/pppd': No such file or directory
mv: can't rename '/home/app/exec/pppoe': No such file or directory
mv: can't rename '/home/app/exec/ss': No such file or directory
mv: can't rename '/home/app/exec/dropbear': No such file or directory
mv: can't rename '/home/app/exec/dropbearkey': No such file or directory
/home/start.sh: line 29: dropbearkey: not found
chmod: /usr/bin/dvrCmd/dvrtools: No such file or directory
----------<3> load hisi sdk ----------
The system mem size is 0x1
load 3535 ok
----------<4> del no use res ----------
mv: can't rename '/home/app/res/adAudio.jpg': No such file or directory
/home/start.sh: line 79: ./pppoed: not found
iSCSI daemon with pid=911 started!!!! the device is not toe !!!
BusyBox v1.16.1 (2016-06-29 13:49:45 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
BusyBox v1.2.1 Protect Shell (psh)
# DDR cpld.sys.bits.ddr_bitw : 1
fun:hisi_3535_get_dev_hard_info, line:2354 ***************** no alarm board****************
!!!!!!!you Device is illegal, Please call factory!!!!!!
^C!!!!!!!you Device is illegal, Please call factory!!!!!!
!!!!!!!you Device buy in cn, you firmware is en err!!!!!!
PHY not link!
OK
Starting kernel ...
Sat Jan  3 00:45:56 UTC 1970
show logo Sat Jan  3 00:46:05 UTC 1970
load 3535 ok
iSCSI daemon with pid=908 started!!!! the device is not toe !!!
PHY not link!
OK
Starting kernel ...
Sat Jan  3 00:46:58 UTC 1970
н\----------<2> show logo ----------
show logo Sat Jan  3 00:47:07 UTC 1970
The system mem size is 0x1                                                    /
load 3535 ok
*  ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY!     *
*  Don't reset machine,or anything that interrupt it. *
*  The upgrade process must finish in 10 minutes!     *
*  If this program fails,machine might be unusable,   *
*  and you will need to reflash again.                *
*  If you find this too risky,power off machine now.  *
Now press [u/U] key to upgrade software: u
File system error,please upgrade by TFTP
Please input ip address of device: 192.0.0.64
Please input ip address of upgrade server: 192.0.0.128
Confirm?(y/n): y
timeout for link [4999]!
Download to address: 0x80008000
Downloading: #  [ Connected ]
################################        [ 1.000 MB]
################################        [ 2.000 MB]
######################T #########T #    [ 3.000 MB]
#####################T ###########      [ 4.000 MB]
################################        [ 5.000 MB]
####T ############################      [ 6.000 MB]
###############T #################      [ 7.000 MB]
########################T ########      [ 8.000 MB]
################################        [ 9.000 MB]
################################        [10.000 MB]
#########################T #######      [11.000 MB]
################################        [12.000 MB]
################################        [13.000 MB]
################################        [14.000 MB]
###########T #####################      [15.000 MB]
done
Bytes transferred = 15942144 (f34200 hex)
digicap.dav match error
Language mismatch: In bootparams is 0x2  but in digicap is 0x1
Please input ip address of upgrade server: done
Confirm?(y/n): Bytes tran421gicap.dav h e
Please input ip address of device: Language at0x1
Confirm?(y/n): done
Как снять дамп, вопрос в силе))
Как я понял у меня не та прошивка))
Прикрепления: 7026024.png (611.3 Kb)
iTuneDVRДата: Четверг, 05.04.2018, 01:05 | Сообщение # 11
Ключевая информация!!!
Устройство чисто чинайское, а прошивка европейская wink
VladKoДата: Четверг, 05.04.2018, 07:01 | Сообщение # 12
Где взять чинайскую прошивку?
iTuneDVRДата: Четверг, 05.04.2018, 14:41 | Сообщение # 13
У чинайцев на чинайском хике, в интернете есть ссылки, были как минимум.
VladKoДата: Четверг, 05.04.2018, 20:51 | Сообщение # 14
Короче нашел вроде китайски сайт этот, скачал там прошивку для DS-78 79N-EX прошивка - NVR_K41_QD_CN_STD_V3.4.98_171121, все прошилось рег начал загружаться но теперь на китайском языке, дошел до настрое по картинкам, языка англ нет. Но как я понял англ заблокирован? Каким способом можно разлочить?
iTuneDVRДата: Четверг, 05.04.2018, 21:11 | Сообщение # 15
Прошивка для внутреннего рынка, как и устройство, а зачем чинайцам английский, когда у них свой есть родной wink
avalistДата: Четверг, 05.04.2018, 23:50 | Сообщение # 16
А посмотрите в web морде есть выбор языка? У меня на китайском был и на английском. Все локальное меню, только китайский.
Так и пользовались через браузер, хоть понятно было. Прошивка тоже с китайского сайта hik, восстанавливал аппарат который клиент привез с ali и случайно обновил международной версией. Вроде был DS-71xx какой-то.
iTuneDVRДата: Пятница, 06.04.2018, 13:22 | Сообщение # 17
Прошивка была патченная, потому аппарат и работал и принял европейскую прошивку.
VladKoДата: Понедельник, 09.04.2018, 20:37 | Сообщение # 18
нет нету((
Как пропатчить? Дайте совет пожалуйста.
Aleksandr398Дата: Среда, 19.06.2019, 23:57 | Сообщение # 19
подскажите как прошить регистратор заново, Регистратор китаец прошил с официального сайта, теперь пищит 15 раз и перезагружается
Добавлено (20.06.2019, 00:25)
Цитата VladKo ()
1- GRD2- RXD
3-TXD
4- не используется
Верно?
Дошел до этой стадии
Добавлено (20.06.2019, 12:58)
U-Boot 2010.06-svn (Aug 15 2015 - 15:18:43)
Protected at offset:0,size:20000 Protection status:[0xf88]=>[0xf8b].
### CRAMFS load complete: 3187728 bytes loaded to 0x80400000
OK
Starting kernel ...
Mon Mar  9 17:09:04 UTC 1970
show logo Mon Mar  9 17:09:14 UTC 1970
load 3535 ok
iSCSI daemon with pid=912 started!!!! the device is not toe !!!
iTuneDVRДата: Четверг, 20.06.2019, 20:45 | Сообщение # 20
Регистратор был чистый чинаец с патченной софтово прошивкой.
Вот он и хочет чисто чинайскую прошивку либо патченный вариант.
Aleksandr398Дата: Суббота, 29.06.2019, 20:05 | Сообщение # 21
Регистратор был чистый чинаец с патченной софтово прошивкой.Вот он и хочет чисто чинайскую прошивку либо патченный вариант.
а где скачать прошивку можно
iTuneDVRДата: Суббота, 29.06.2019, 20:23 | Сообщение # 22
Спросить у продавца, если он добрый и вышлет.
Aleksandr398Дата: Суббота, 29.06.2019, 22:41 | Сообщение # 23
Продавца контактов нет и регистратору сто лет в обед, подскажи где качнуть
OleglevshaДата: Суббота, 29.06.2019, 22:47 | Сообщение # 24
Ремонт видеорегистраторов и видеокамер из поднебесной возможен в славном городе Волгоград...
Aleksandr398Дата: Суббота, 29.06.2019, 22:49 | Сообщение # 25
Прошивка нужна китайская не подскажешь где качнуть. Рег галимый китай
Добавлено (29.06.2019, 22:55)
Confirm?(y/n): y
MAC:   BC-AD-28-E5-15-F0
################################        [ 3.000 MB]
################################        [ 4.000 MB]
################################        [ 6.000 MB]
################################        [ 7.000 MB]
################################        [ 8.000 MB]
################################        [11.000 MB]
################################        [15.000 MB]
done
Bytes transferred = 16351813 (f98245 hex)
Прошивка не подходит
OleglevshaДата: Воскресенье, 30.06.2019, 07:58 | Сообщение # 26
На китайском сайте Hikvision
http://www1.hikvision.com/cn/download_more_699.html#prettyPhoto
Aleksandr398Дата: Суббота, 06.07.2019, 13:13 | Сообщение # 27
На китайском сайте Hikvisionhttp://www1.hikvision.com/cn/download_more_699.html#prettyPhoto
Спасибо
Добавлено (08.07.2019, 14:15)
Подскажите где можно найти прошивку или что можно сделать?
OleglevshaДата: Понедельник, 08.07.2019, 21:14 | Сообщение # 28
Я могу исправить, пришлите в Волгоград, стоимость 1500р + почтовые расходы
Aleksandr398Дата: Понедельник, 08.07.2019, 21:26 | Сообщение # 29
Если б жил поблизости то без проблем, а так дешевле новый купить, либо договориться сколько прошивка стоить будет если скинете на почту
OleglevshaДата: Понедельник, 08.07.2019, 21:40 | Сообщение # 30
Ремонт производится только при условии наличия девайса у меня в мастерской,
Поищите сервисный центр в своем регионе...
Aleksandr398Дата: Среда, 10.07.2019, 22:39 | Сообщение # 31
Помогите пропатчить китайскую прошиву на русский или английский
iTuneDVRДата: Четверг, 11.07.2019, 14:09 | Сообщение # 32
Выше предложено решение вопроса или запрос на научить?
Aleksandr398Дата: Пятница, 12.07.2019, 21:07 | Сообщение # 33
помочь
iTuneDVRДата: Суббота, 13.07.2019, 00:51 | Сообщение # 34
Продай этот как есть, купи другой правильный.
Сообщение отредактировал iTuneDVR - Суббота, 13.07.2019, 00:51
cahek127Дата: Вторник, 08.10.2019, 12:12 | Сообщение # 35
добрый день, есть регистратор ds 7604n-e1/4p китаец, был случайно прошит европейской прошивкой.  при включении теперь пищит 15 раз и перегружается. через tftp не шьется китайской прошивкой, хотя пингуется. в tftp висит строка [2019-10-07 13:20:03] TFTP server[192.0.0.128] initialized и все, подскажите как вернуть к жизни регик)
Сообщение отредактировал cahek127 - Вторник, 08.10.2019, 12:58
iTuneDVRДата: Вторник, 08.10.2019, 23:21 | Сообщение # 36
Прошить оригинальной чинайской прошивкой с чинайского сайта wink
cahek127Дата: Среда, 09.10.2019, 07:23 | Сообщение # 37
а как? через tftp не получается, висит на этом TFTP server[192.0.0.128] initialized и все
на регике пишется embedded nvr
Сообщение отредактировал cahek127 - Среда, 09.10.2019, 07:43
iTuneDVRДата: Среда, 09.10.2019, 21:40 | Сообщение # 38
Подключиться к TTL разъему адаптером и оттуда.
cahek127Дата: Четверг, 17.10.2019, 20:15 | Сообщение # 39
Подскажите нету не у кого прошивки для китайцев с русским языком?? Может кто нашел поделитесь пожалуйста
Добавлено (18.10.2019, 15:19)
Подскажите знающие, если я куплю регистратор у официалов он не увидит мои китайские камеры, я правильно понимаю?
На алике продают регистраторы  типо английскую версию и поддерживающие обновление прошивок - это тоже развод или что то поменялось ???
Добавлено (18.10.2019, 15:24)
https://ru.aliexpress.com/item....48998.2
iTuneDVRДата: Пятница, 18.10.2019, 19:31 | Сообщение # 40
Не совсем развод, но может быть, что конкретное устройство с пропатченной прошивкой и оно работает как европеец.
