DS-2CD2542FWD-IS
DrGEM | Дата: Четверг, 09.04.2020, 14:39 | Сообщение # 1 |
| Здравствуйте. Пришло 2 тела DS-2CD2542FWD-IS с похожими симптомами - не работают. Что и как было до - не известно, предполагаю что их выкинули а клиент взял как хорошие.
Лог старта
U-Boot 3.1.6-195297 (May 25 2016-11:39:03) boards:195277 Boot From: NAND 2048 RC SYS_CONFIG: 0x30060059 POC: 100 Cortex freq: 600000000 ENET freq: 50000000 iDSP freq: 216000000 Dram freq: 564000000 Core freq: 216000000 AHB freq: 108000000 APB freq: 54000000 UART freq: 24000000 SD freq: 50000000 SDIO freq: 50000000 SDXC freq: 60000000
dev_model:DS-2CD2542FWD-IS
*** Warning - bad CRC, using default environment crc=0xC1CD2D34,env.crc=0xFFFFFFFF |NUL eth| cmd 'null' is not supported. nand booting ... booting from pri part... load kernel...
init started: BusyBox v1.19.3 (2019-08-26 15:55:19 CST) starting pid 46, tty '': '/etc/init.d/rcS' Starting udev: [ OK ] UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi1_0. waiting for /dev/ubi1_0. pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1 UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi3_0. Check dir /davinci ok! (0) UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi4_0. waiting for /dev/ubi4_0. Check dir /config ok! (0) diagnose_way = 15, repair_way = 1, interval = 60 route: ioctl 0x890c failed: No such process Default method to init without VIN drivers... Cat this file to find out what VIN can be supported. Default init without lens driver Use default settings /home/script/init.sh: line 553: which: not found / [ 19.925251] [ kernel version: svn-594950 ] map_size = 0x400000, nr_item = 3 addr_offset = 0x00000000, filename = orccode.bin addr_offset = 0x00300000, filename = orcme.bin addr_offset = 0x003a0000, filename = default_binary.bin mmap returns 0x76ab0000 loading /home/firmware/orccode.bin...addr = 0x76ab0000, size = 0x171cca loading /home/firmware/orcme.bin...addr = 0x76db0000, size = 0x51644 loading /home/firmware/default_binary.bin...addr = 0x76e50000, size = 0x40000
ucode (S2L) version = 2017/5/25 271820.271498
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus 0 .
Enter DB_main-------------------
shared memory address is: 0x76bbf000, sizeof(DEVICECONFIG) = 1159944
netprocess Infomation:
version: 8.11.3 [14:45:39-Jun 22 2018]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 404021
Last Changed Date: 2018-06-22 14:14:20 +0800 (Fri, 22 Jun 2018)
wait davinci set default...
[04-09 13:15:03][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:03][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:03][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:03][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
copy default.cls ok.
[04-09 13:15:04][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:04][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:04][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:04][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[04-09 13:15:05][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:05][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:05][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:05][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
shared memory address is: 0x769bb000, sizeof(DEV_CAPABILITY) = 464336
[04-09 13:15:05][pid:593][HW_IF][ERROR]sec info get inval!!!
[04-09 13:15:05][pid:593][SYSINIT][ERROR]hwif_getsecinfo failed.
[04-09 13:15:05][pid:593][SYSINIT][ERROR]sys app init failed to reboot!
[04-09 13:15:06][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:06][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:06][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:06][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[04-09 13:15:07][pid:572][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[04-09 13:15:07][pid:579][STRM_ANLS] [ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012]
[04-09 13:15:07][pid:579][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[04-09 13:15:07][pid:579][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 30.831013] Restarting system.
При прошивке ,по совету с форума лил младшую. Firmware_IPC_Raptor series_En_V5.3.8 151224 Лог. U-Boot 3.1.6-195297 (May 25 2016-11:39:03)
boards:195277
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
Hit Ctrl+u to stop autoboot: 2 Hit Ctrl+u to stop autoboot: 1 Hit Ctrl+u to stop autoboot: 0
Formatting ............................................................................................................................................................................................................ done!
[ INFO][MIN]TFTP: TFTP from server 192.168.1.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
[ INFO][MIN]TFTP: ################################################################################
[ INFO][MIN]TFTP: Download File
[OK][ INFO][MIN]BURN: File size is 33322648 bytes (32541 KB)
[ INFO][MIN]BURN: Writing Flash
[ INFO][MIN]BURN: ..............................................................................................................
[ INFO][MIN]BURN: Write Flash
[OK]***** UPDATE COMPLETE *****
BusyBox v1.2.1 Protect Shell (psh)
# help
Support Commands:
taskShow printPart prtHardInfo
getPreviewStatus setIp setV6ip
setGateway dspStatus outputClose
outputOpen getDebug setDebug
debugLog getIrstate getMtu
camCmd getCamVer getIrstate
getLux getMcuInfo getMotion
getRawdata setIrcmd setRectFrame
updateCamera setLaserMode getLaserMode
setIrMode getIrMode setBaiguangMode
getBaiguangMode setYTLock InquireFanSwitch
StartLaser CloseLaser LaserMotReset
EnlargeCur ReduceCur SetCur
LaserMotDirect LaserTeleOffset LaserWideOffset
InqSwitch InqCurrent InqCurMotDirect
getMcuStateInfo setFastFocus getTrackStatus
getSelfcheckResult setLdcMode getLdcMode
getPreviewStatus appCmd camCmd
ezoomlens_start_t2_test prtLensCurve getLensCurve
getIp gdbcfg {Test1}
{Test2} {Test3} {Test4}
{TestN} {TestY} getIsp
getISP getisp setIsp
setISP setisp regread
regwrite setAgingMode getAgingMode
setAgingTime getAgingTime setLensZoomPos
getLensZoomPos dm365 ss
showKey showServer showUpnp
showStatus showDefence setLBS
setAlarm cloudService t1
ifconfig netstat ping
ping6 top iostat
mpstat ps reset
dmesg exit getDateInfo
diagnose help
Вторая камера аналогично ведет себя кроме того что не ругается на контрольную сумму Warning - bad CRC, using default environment
В линуксе не силен , с паяльником дружу, прошелся по форуму но видно не заметил направление правильного движения - пните в нужное. Спасибо.Добавлено (09.04.2020, 14:57) --------------------------------------------- Забыл сказать, слил дамп с нанда программатором 132Мб.
iTuneDVR | Дата: Четверг, 09.04.2020, 16:35 | Сообщение # 2 |
| Цитата DrGEM ( ) [04-09 13:15:05][pid:593][HW_IF][ERROR]sec info get inval!!!
Вероятно ключевые строки
Надо глядеть в дамп, чтобы понять что там есть, а чего нет. На ошибку CRC не обращай сильно внимание.
DrGEM | Дата: Четверг, 09.04.2020, 16:59 | Сообщение # 3 |
| iTuneDVR, Здравствуйте , спасибо за ответ. secinfo я так понимаю это информация о камере (серийник, клоуд итд). А в каком виде она представляется в этих девайсах ? Это отдельный файл или определенный адрес в дампе где прописано , в явном виде или же скрытом ? ЗЫ iTuneDVR, гляньте ПМ
iTuneDVR | Дата: Четверг, 09.04.2020, 17:27 | Сообщение # 4 |
| Цитата DrGEM ( ) При прошивке ,по совету с форума лил младшую. Firmware_IPC_Raptor series_En_V5.3.8 151224 Лог.
DS-2CD2542FWD-I(W)(S) это R6 !!!!!!!!!!!!!!!!!!!! А тут по логу и названию прошивки вливалась от R0!!!
Сообщение отредактировал iTuneDVR - Четверг, 09.04.2020, 17:27 |
DrGEM | Дата: Четверг, 09.04.2020, 17:46 | Сообщение # 5 |
| Цитата iTuneDVR ( ) по логу и названию прошивки Вот что я вливал. Вроде R6 написано. Или имеете в виду в дампе что творилось до меня ?
iTuneDVR | Дата: Пятница, 10.04.2020, 13:21 | Сообщение # 6 |
| Цитата DrGEM ( ) Вот что я вливал. Вроде R6 написано. Или имеете в виду в дампе что творилось до меня ? Тут распакованный размер Цитата DrGEM ( ) Вот что я вливал. Вроде R6 написано. Или имеете в виду в дампе что творилось до меня ? 25 984 098
Цитата DrGEM ( ) [ INFO][MIN]TFTP: Download File [OK][ INFO][MIN]BURN: File size is 33322648 bytes (32541 KB) [ INFO][MIN]BURN: Writing Flash
тут от IPC_R6_EN_STD_5.5.82_190220, что и смутило вначале.
Я доверяю тому, что написано, потому и предположил, без конкретных данных, что вливается не то потом конечно карта разделов разная в устройствах. Поскольку происхождение камер неизвестно, то могли с ними делать все что угодно, а потом гадай.
На шильдике камеры какая прошивка написана?
По дампу шифрованный системный раздел на месте и по остальным разделам на вскидку на месте. Есть конечно рабочие дампы с других R6 камер и можно так-то пересобрать с учетом твоей системной информации. Так уже делалось и все начинало работать.
Если две камеры одинаковые, то есть смысл снять дамп со второй и убедиться что они не клонированы. Мало ли...
DrGEM | Дата: Пятница, 10.04.2020, 13:42 | Сообщение # 7 |
| На шильдике V 5.4.3_160902 на обеих камерах. Второй дамп снял, отличий "относительно" много, не похоже на клон. Вроде появилась рабочая камера на слитие дампа, обещали на сл. неделе. А есть где прочитать про организацию дампа на них , строение, адреса , монтирование ?
iTuneDVR | Дата: Пятница, 10.04.2020, 16:47 | Сообщение # 8 |
| Давай глянем на дамп, так же, чтобы было понятно. На второй такой же лог загрузки?
DrGEM | Дата: Пятница, 10.04.2020, 21:16 | Сообщение # 9 |
| Да, лог такой же. Только не ругается на CRC. Дамп сливал на рабочем компе и доступ будет только в понедельник. Не подскажете где находится secinfo в дампе?
Сообщение отредактировал DrGEM - Пятница, 10.04.2020, 21:19 |
iTuneDVR | Дата: Воскресенье, 12.04.2020, 15:23 | Сообщение # 10 |
| Цитата DrGEM ( ) На шильдике V 5.4.3_160902 на обеих камерах. Второй дамп снял, отличий "относительно" много, не похоже на клон. Вроде появилась рабочая камера на слитие дампа, обещали на сл. неделе. А есть где прочитать про организацию дампа на них , строение, адреса , монтирование ?
Вот видимо и младшая. Относительность понятие относительное, но вполне конкретное. Важны конкретные области по расположению, если брать за основу мысль что две камеры одинаковы с одинаковыеи шильдиками и на старте в логах даты и версии идентичны.
Цитата DrGEM ( ) Да, лог такой же. Только не ругается на CRC. Дамп сливал на рабочем компе и доступ будет только в понедельник. Не подскажете где находится secinfo в дампе?
0039C000-0039C7FF
DrGEM | Дата: Среда, 15.04.2020, 12:34 | Сообщение # 11 |
| Принесли камеру, только другую (2CD2543) дамп не снял. Вопрос пока открыт. iTuneDVR, ПМ
iTuneDVR | Дата: Среда, 15.04.2020, 12:54 | Сообщение # 12 |
| В подобной ситуации, чтобы убедиться, что железо действительно исправно, я предлагал коллегам брать дамп с заведомо рабочей камеры и делать клона и убедишись, что все работает дальше пересобирать дамп с учетом предполагаемой родной и целой системной информацией. Либо вариант, заменить блок только системной информации на заведомо исправную. Можно попробовать конечно потестить флеш и стереть его и записать заново оригинал, потому как и такое прокатывало.
DrGEM | Дата: Среда, 15.04.2020, 13:01 | Сообщение # 13 |
| Оригинальную NAND я выпаял и не трогаю, содержимое залил на тестовую самсунговскую которая упоминается в дампе. На ней и произвожу эксперименты.
iTuneDVR | Дата: Среда, 15.04.2020, 17:15 | Сообщение # 14 |
| Наблюдаю схожее на случае с g1 серией на камере 2043g0-i, вот так нежданно негаданно.
DrGEM | Дата: Среда, 15.04.2020, 17:30 | Сообщение # 15 |
| А что именно ? Где читать ? Это ?
iTuneDVR | Дата: Среда, 15.04.2020, 20:31 | Сообщение # 16 |
| Нет, там другое. Добавлено (18.04.2020, 11:06) --------------------------------------------- Стоит раскрыть камеру и найти 8-ми контактную микросхему с названием VS16... Возможно она есть и она неисправна, либо наоборот её нет снята и без неё не будет (не должно) работать штатно...
DrGEM | Дата: Суббота, 18.04.2020, 13:07 | Сообщение # 17 |
| Да имеется такая микросхема. Как проверить её на исправность? Кто это ? Как не штатно запустить камеру ?
Добавлено (18.04.2020, 13:38) --------------------------------------------- Это какой-то шифровщик ?
_____ GND 1 --| |--8 +3v3 2 --| |--7 DAT? 3 --| |--6 CLK (?) 4 --| |--5 ------ На 3-тей ноге при -- load kernel... -- в терминале, осцилом просматривается обмен пакетами. Если успею сегодня зацеплю анализатор посмотреть на что похожи пакеты.Добавлено (18.04.2020, 14:48) --------------------------------------------- Может это что то вроде OTP Key типа DM2016
Сообщение отредактировал DrGEM - Суббота, 18.04.2020, 13:39 |
iTuneDVR | Дата: Суббота, 18.04.2020, 17:04 | Сообщение # 18 |
| Чуть больше информации тут https://ipcamtalk.com/threads....s.16275
Без него не будет работать штатно. Возможен конечно вариант патча для R6, что явно проще в дальнейшей сборке в виде пользовательской прошивки.
Конспирология: Возможно, что она живая, но чинайцы решили по другому и это заведомое "старение" устройства, но будем надеяться, что что на не живая и не будем думать плохо о чинайцах....
DrGEM | Дата: Среда, 22.04.2020, 12:11 | Сообщение # 19 |
| Подключил анализатор с плагином ISO7816 - ни чего не понял из протокола общения. Ясно что при запуске они общаются, а вот как понять договорились они или нет, не понятно. Где прочитать про патч на R6 и сборку прошивки ? Камеры выкупил на фарш так что терять не чего. Добавлено (22.04.2020, 12:55) --------------------------------------------- Отредактировал ENV setenv bootargs console=ttyS0 debug=9 single KRN_PRT=pri получил более содержательный лог
U-Boot 3.1.6-195297 (May 25 2016-11:39:03) boards:195277 Boot From: NAND 2048 RC SYS_CONFIG: 0x30060059 POC: 100 Cortex freq: 600000000 ENET freq: 50000000 iDSP freq: 216000000 Dram freq: 564000000 Core freq: 216000000 AHB freq: 108000000 APB freq: 54000000 UART freq: 24000000 SD freq: 50000000 SDIO freq: 50000000 SDXC freq: 60000000 dev_modelS-2CD2542FWD-IS Hit Ctrl+u to stop autoboot: 0 |RCV UDP pack timeout| cmd 'null' is not supported. nand booting ... booting from pri part... load kernel... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.10.73+ (zhangjianzhong@Cpl-Frt-BSP) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #12 PREEMPT Thu Jul 20 11:10:40 CST 2017 [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board [ 0.000000] dev type:0x2218 [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0 [ 0.000000] Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0 [ 0.000000] Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9 [ 0.000000] Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0 [ 0.000000] Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0 [ 0.000000] Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0 [ 0.000000] Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0 [ 0.000000] Ambarella: IAVMEM = 0x07000000[ ],0x09000000 [ 0.000000] Ambarella: FBMEM = 0x06800000[ ],0x00000000 [ 0.000000] On node 0 totalpages: 28160 [ 0.000000] free_area_init_node: node 0, pgdat 807d48f8, node_mem_map 80805000 [ 0.000000] Normal zone: 220 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 28160 pages, LIFO batch:7 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 27940 [ 0.000000] Kernel command line: console=ttyS0 debug=9 KRN_PRT=pri KRN_PRT=pri [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes) [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Memory: 110MB = 110MB total [ 0.000000] Memory: 103360k/103360k available, 9280k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 k [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 k [ 0.000000] vmalloc : 0x87000000 - 0xff000000 (1920 M [ 0.000000] lowmem : 0x80000000 - 0x86e00000 ( 110 M [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 M [ 0.000000] .text : 0x80008000 - 0x80502750 (5098 k [ 0.000000] .init : 0x80503000 - 0x80793bd4 (2627 k [ 0.000000] .data : 0x80794000 - 0x807dc690 ( 290 k [ 0.000000] .bss : 0x807dc690 - 0x808002b0 ( 144 k [ 0.000000] NR_IRQS:240 [ 0.000000] sched_clock: 32 bits at 54MHz, resolution 18ns, wraps every 79536ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [ttyS0] enabled [ 0.273236] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032) [ 0.332603] pid_max: default: 32768 minimum: 301 [ 11.131854] Mount-cache hash table entries: 512 [ 11.138813] CPU: Testing write buffer coherency: ok [ 11.143981] Setting up static identity map for 0x803cbe08 - 0x803cbe78 [ 11.153914] devtmpfs: initialized [ 11.158414] pinctrl core: initialized pinctrl subsystem [ 11.163956] NET: Registered protocol family 16 [ 11.169132] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 11.176521] L310 cache controller enabled [ 11.180556] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B [ 11.189946] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered [ 11.197958] ambarella-gpio gpio.0: Ambarella GPIO driver registered [ 11.205761] read dev-tree[misc_ctrl_pin] pro [rst_time] error! [ 11.211600] read dev-tree[misc_ctrl_pin] pro [rst_delay] error! [ 11.220033] bio: create slab <bio-0> at 0 [ 11.225099] ambarella-dma e0005000.dma: Ambarella DMA Engine [ 11.232755] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed! [ 11.239733] Advanced Linux Sound Architecture Driver Initialized. [ 11.246570] Switching to clocksource ambarella-cs-timer [ 11.258309] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x86720000<->0x06920000] [ 11.266623] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000 [ 11.275495] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA [ 11.351907] ambarella-sd e0002000.sdmmc0: 1 slots @ 50000000Hz [ 11.357884] NET: Registered protocol family 2 [ 11.363138] TCP established hash table entries: 1024 (order: 1, 8192 bytes) [ 11.370104] TCP bind hash table entries: 1024 (order: 0, 4096 bytes) [ 11.377577] TCP: Hash tables configured (established 1024 bind 1024) [ 11.384001] TCP: reno registered [ 11.387219] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 11.393067] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 11.399494] NET: Registered protocol family 1 [ 11.404157] RPC: Registered named UNIX socket transport module. [ 11.410060] RPC: Registered udp transport module. [ 11.414801] RPC: Registered tcp transport module. [ 11.419484] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 11.624254] msgmni has been set to 201 [ 11.629318] NET: Registered protocol family 38 [ 11.633930] io scheduler noop registered [ 11.637836] io scheduler deadline registered [ 11.642144] io scheduler cfq registered (default) [ 11.647677] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart [ 11.655453] brd: module loaded [ 11.661103] loop: module loaded [ 11.667010] ambarella-nand e0001000.nand: in ecc-[1]bit mode [ 11.672698] ambarella_nand: Use On Flash BBT [ 11.677020] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64 [ 11.689248] Bad block table found at page 65472, version 0x03 [ 11.695168] Bad block table found at page 65408, version 0x03 [ 11.701059] nand_read_bbt: bad block at 0x0000002e0000 [ 11.706205] nand_read_bbt: bad block at 0x000004040000 [ 11.711407] 16 ofpart partitions found on MTD device amba_nand [ 11.717239] Creating 16 MTD partitions on "amba_nand": [ 11.722404] 0x000000000000-0x000000020000 : "bst" [ 11.727868] 0x000000020000-0x000000120000 : "bld" [ 11.733285] 0x000000120000-0x000000200000 : "ptb" [ 11.738590] 0x000000200000-0x000000280000 : "env" [ 11.743984] 0x000000280000-0x000000380000 : "sysflg" [ 11.749600] 0x000000380000-0x000000400000 : "param" [ 11.755204] 0x000000400000-0x000000500000 : "dpt" [ 11.760555] 0x000000500000-0x000000f00000 : "rcvy" [ 11.766080] 0x000000f00000-0x000001700000 : "krn_pri" [ 11.771793] 0x000001700000-0x000001f00000 : "krn_sec" [ 11.777603] 0x000001f00000-0x000004100000 : "app_pri" [ 11.783449] 0x000004100000-0x000006300000 : "app_sec" [ 11.789169] 0x000006300000-0x000006900000 : "cfg_pri" [ 11.794912] 0x000006900000-0x000006f00000 : "cfg_sec" [ 11.800590] 0x000006f00000-0x000007700000 : "dbg" [ 11.806012] 0x000007700000-0x000007f00000 : "syslog" [ 11.812159] ambarella-spi e0020000.spi: SPI[0] uses DMA [ 11.817520] ambarella-spi e0020000.spi: Ambarella spi controller 0 created. [ 11.824723] tun: Universal TUN/TAP device driver, 1.6 [ 11.829755] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 11.891852] libphy: Ambarella MII Bus: probed [ 11.896206] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@0 has invalid PHY address [ 11.905337] mdio_bus e000e000.etherne: scan phy phy at address 0 [ 11.912832] mdio_bus e000e000.etherne: registered phy phy at address 0 [ 11.919353] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816! [ 11.926655] ambarella-eth e000e000.ethernet: MAC Address[a4:14:37:5c:7a:bb]. [ 11.933800] PPP generic driver version 2.4.2 [ 11.938246] PPP BSD Compression module registered [ 11.942969] PPP Deflate Compression module registered [ 11.948172] mousedev: PS/2 mouse device common for all mice [ 14.951864] ambarella-i2c e8003000.i2c: No ACK from address 0xa2, 0:0! [ 14.958734] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0 [ 14.966419] pcf85163 is not exist. [ 14.969801] i2c /dev entries driver [ 14.973823] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed. [ 14.981150] Netfilter messages via NETLINK v0.30. [ 14.985971] nf_conntrack version 0.5.0 (1615 buckets, 6460 max) [ 14.992258] ip_tables: © 2000-2006 Netfilter Core Team [ 14.997597] TCP: cubic registered [ 15.000925] NET: Registered protocol family 10 [ 15.006290] ip6_tables: © 2000-2006 Netfilter Core Team [ 15.011716] sit: IPv6 over IPv4 tunneling driver [ 15.016978] NET: Registered protocol family 17 [ 15.021483] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 15.029158] ThumbEE CPU extension supported. [ 15.034590] ambarella-rtc e8015000.rtc: setting system clock to 2106-02-07 06:28:15 UTC (4294967295) [ 15.043828] ALSA device list: [ 15.046780] No soundcards found. [ 15.052888] Freeing unused kernel memory: 2624K (80503000 - 80793000) init started: BusyBox v1.19.3 (2017-07-20 11:10:26 CST) starting pid 46, tty '': '/etc/init.d/rcS' Starting udev: [ OK ] Добавлено (22.04.2020, 12:55) --------------------------------------------- [ 15.646644] UBI: attaching mtd10 to ubi1 [ 15.736836] UBI: scanning is finished [ 15.751056] UBI: attached mtd10 (name "app_pri", size 34 Mi to ubi1 [ 15.760284] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes [ 15.767135] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 15.773839] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 15.780689] UBI: good PEBs: 271, bad PEBs: 1, corrupted PEBs: 0 [ 15.786598] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 15.793721] UBI: max/mean erase counter: 841/222, WL threshold: 4096, image sequence number: 871084521 [ 15.803009] UBI: available PEBs: 0, total reserved PEBs: 271, PEBs reserved for bad PEB handling: 9 [ 15.812052] UBI: background thread "ubi_bgt1d" started, PID 271 UBI device number 1, total 271 LEBs (34410496 bytes, 32.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki waiting for /dev/ubi1_0. [ 15.833586] UBIFS: background thread "ubifs_bgt1_0" started, PID 276 [ 15.859857] UBIFS: recovery needed [ 15.912672] UBIFS: recovery completed [ 15.916526] UBIFS: mounted UBI device 1, volume 0, name "app_pri" [ 15.922677] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 15.931785] UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs) [ 15.941429] UBIFS: reserved for root: 1487352 bytes (1452 Ki [ 15.947262] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 7E5D4477-3FA9-4CAA-8A56-AF37F226493F, small LPT model pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1 [ 15.970368] UBI: attaching mtd12 to ubi3 [ 15.989785] UBI: scanning is finished [ 16.003569] UBI: attached mtd12 (name "cfg_pri", size 6 Mi to ubi3 [ 16.009909] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes [ 16.019443] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 16.026209] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 16.033085] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0 [ 16.038893] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 16.046018] UBI: max/mean erase counter: 7542/5942, WL threshold: 4096, image sequence number: 1159182107 [ 16.055567] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10 [ 16.064611] UBI: background thread "ubi_bgt3d" started, PID 280 UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki waiting for /dev/ubi3_0. [ 16.086115] UBIFS: background thread "ubifs_bgt3_0" started, PID 285 [ 16.112668] UBIFS: recovery needed [ 16.129970] UBIFS: recovery completed [ 16.133875] UBIFS: mounted UBI device 3, volume 0, name "cfg_pri" [ 16.139995] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 16.149132] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs) [ 16.158425] UBIFS: reserved for root: 143937 bytes (140 Ki [ 16.164080] UBIFS: media format: w4/r0 (latest is w4/r0), UUID D703E8B0-C688-43A6-9DF7-BC0102AC4A13, small LPT model Check dir /davinci ok! (0) [ 16.189822] UBI: attaching mtd13 to ubi4 [ 16.209212] UBI: scanning is finished [ 16.212882] probe_rst_pin exceed [ 16.226382] UBI: attached mtd13 (name "cfg_sec", size 6 Mi to ubi4 [ 16.235491] UBI: PEB size: 131072 bytes (128 Ki, LEB size: 126976 bytes [ 16.242336] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048 [ 16.249013] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 16.255882] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0 [ 16.261690] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 16.268811] UBI: max/mean erase counter: 2704/1632, WL threshold: 4096, image sequence number: 2001898068 [ 16.278358] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10 [ 16.287398] UBI: background thread "ubi_bgt4d" started, PID 290 UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 Mi, available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 Ki waiting for /dev/ubi4_0. [ 16.308855] UBIFS: background thread "ubifs_bgt4_0" started, PID 295 [ 16.336151] UBIFS: recovery needed [ 16.354071] UBIFS: recovery completed [ 16.357926] UBIFS: mounted UBI device 4, volume 0, name "cfg_sec" [ 16.364082] UBIFS: LEB size: 126976 bytes (124 Ki, min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 16.373208] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs) [ 16.382497] UBIFS: reserved for root: 143937 bytes (140 Ki [ 16.388139] UBIFS: media format: w4/r0 (latest is w4/r0), UUID ACFAF1FC-D283-4D13-AF3F-903A6CB6F424, small LPT model Check dir /config ok! (0) diagnose_way = 15, repair_way = 1, interval = 60 [ 16.453068] net eth0: adv: sym 1, asym: 1 [ 16.457239] net eth0: lp: sym: 0, asym: 0 [ 16.461299] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready route: ioctl 0x890c failed: No such process [ 18.451629] dsp: module license 'Proprietary' taints kernel. [ 18.457596] net eth0: lp: sym: 1, asym: 1 [ 18.461592] libphy: e000e000.etherne:00 - Link is Up - 100/Full [ 18.469685] Disabling lock debugging due to kernel taint [ 18.475088] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 18.515461] img: IMG KERN VIRT: WR [0x87329000, 184 KB], RD [0x84750000, 36 KB]. Default method to init without VIN drivers... Cat this file to find out what VIN can be supported. Default init without lens driver [ 18.624619] amba_debug_init 248:248. Use default settings /home/script/init.sh: line 553: which: not found / [ 18.842188] base module init. [ 18.857870] [ kernel version: svn-300837 ] [ 18.866805] mmc0 power register success! [ 18.870755] mmc1 power register success! [ 18.874740] request sd[mmc1] power ctrl pin error! [ 18.879511] usb0 power register success! [ 18.899359] usbcore: registered new interface driver usbfs [ 18.912914] usbcore: registered new interface driver hub [ 18.921674] usbcore: registered new device driver usb [ 18.932535] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 18.945260] ehci-ambarella: AMBARELLA-EHCI Host Controller driver [ 18.951533] ambarella-ehci e0018000.ehci: EHCI Host Controller [ 18.957514] ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1 [ 18.965738] ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000 [ 18.993516] ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00 [ 18.999938] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 19.006892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 19.014119] usb usb1: Product: EHCI Host Controller [ 19.018977] usb usb1: Manufacturer: Linux 3.10.73+ ehci_hcd [ 19.024541] usb usb1: SerialNumber: AmbUSB [ 19.031349] hub 1-0:1.0: USB hub found [ 19.040446] hub 1-0:1.0: 2 ports detected map_size = 0x400000, nr_item = 3 addr_offset = 0x00000000, filename = orccode.bin addr_offset = 0x00300000, filename = orcme.bin addr_offset = 0x003a0000, filename = default_binary.bin mmap returns 0x76a45000 loading /home/firmware/orccode.bin...addr = 0x76a45000, size = 0x171cca loading /home/firmware/orcme.bin...addr = 0x76d45000, size = 0x51644 loading /home/firmware/default_binary.bin...addr = 0x76de5000, size = 0x40000 =============================================== ucode (S2L) version = 2017/5/25 271820.271498 =============================================== ln: prtLensCurve: File exists ln: /dev/ttyS1: File exists ln: /bin/t1: File exists cp: can't stat '/dav/libutils.so': No such file or directory chmod: /lib/libutils.so: No such file or directory ln: /dev/rtc: File exists =====check_config start===== ===db file doesn't exist=== ===db file doesn't exist=== ==== both config files are broken==== infd read End Unix bus 0 .
netprocess Infomation: version: 5.10.2 [20:30:33-Jul 18 2017] Path: /Camera/Platform/Trunk/FSP_network_protocol Last Changed Rev: 299284 Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017) .
Enter DB_main------------------- shared memory address is: 0x76c5a000, sizeof(DEVICECONFIG) = 959848 wait davinci set default... [01-01 00:00:24][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [01-01 00:00:24][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [01-01 00:00:24][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [01-01 00:00:24][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!! copy default.cls ok. [01-01 00:00:25][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [01-01 00:00:25][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [01-01 00:00:25][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [01-01 00:00:25][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!! [01-01 00:00:26][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [01-01 00:00:26][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [01-01 00:00:26][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [01-01 00:00:26][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!! Unix bus End shared memory address is: 0x76934000, sizeof(DEV_CAPABILITY) = 258664 [01-01 00:00:27][pid:567][HW_IF][ERROR]sec info get inval!!! [01-01 00:00:27][pid:567][SYSINIT][ERROR]hwif_getsecinfo failed. [01-01 00:00:27][pid:567][SYSINIT][ERROR]sys app init failed to reboot! [01-01 00:00:27][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [01-01 00:00:27][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [01-01 00:00:27][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [01-01 00:00:27][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!! [01-01 00:00:28][pid:546][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [01-01 00:00:28][pid:553] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [01-01 00:00:28][pid:553][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [01-01 00:00:28][pid:553][UNI_IF][ERROR]communicaite_to_davinci failed!!! [ 29.731041] ambarella-wdt e800c000.wdt: ambarella_wdt_shutdown @ 4. [ 29.737339] Restarting system.
aavan | Дата: Пятница, 26.03.2021, 10:54 | Сообщение # 20 |
| DrGEM, чем все закончилось?
iTuneDVR | Дата: Пятница, 26.03.2021, 13:38 | Сообщение # 21 |
| Дело с криптой - дело не простое. Сам наткнулся на такую ситуацию. правда чуть в другом ракурсе, но тем не менее. По второму логу и учитывая свой полученный опыт перезагрузка должна произойти раньше, чем она происходит, а значит, возможно не та прошивка стоит. Я то конечно капнул глубже и там есть над чем поразмыслить, чтобы все это дело сэмулировать как-то...
DrGEM | Дата: Среда, 21.04.2021, 10:44 | Сообщение # 22 |
| Камеры до сих пор валяются не тронутыми. Если есть мысли то я готов реализовать на моих камерах. Они на полке для запчастей уже.
iTuneDVR | Дата: Четверг, 22.04.2021, 11:05 | Сообщение # 23 |
| Цитата DrGEM ( ) Камеры до сих пор валяются не тронутыми. Если есть мысли то я готов реализовать на моих камерах. Они на полке для запчастей уже. Есть пара рабочих решений этого вопроса с камерами R6 серии. Есть некоторые нюансы, но камера работает. Минус для владельцев этих камер в том, что решения, пока не в публичном поле. Поэтому, с одной стороны, с полки для запчастей их лучше упаковать в коробки и передвинуть на другую полку, нового оборудования, оставив до лучших дней нетронутыми. С другой стороны, можно так же упаковать в коробки и выслать в дар для проведения экспериментов, если ты уже смирился и они тебе точно не нужны, а продавать за беЗценок нет и смысла никакого, а так ...
