Регистратор после прошивки пищит 15 раз
VladKo | Дата: Понедельник, 02.04.2018, 20:36 | Сообщение # 1 |
| Прошил регистратор (DS-7604N-E1/4P) не той прошивкой, после ребута он включается коротким сигналом, появляется заставка, и при заставке пищит 15 раз длинными сигналами. Пробовал сейчас прошить через TFTP, но ситуация не изменилась, лог TFTP:
Цитата [2018-04-02 22:01:48] TFTP server[192.0.0.128] initialized
[2018-04-02 22:25:10] TFTP server[127.0.0.1] initialized
[2018-04-02 22:26:12] TFTP server[127.0.0.1] initialized
[2018-04-02 22:27:22] Device[192.0.0.64] test tftpserver
[2018-04-02 22:27:22] Connect client[192.0.0.64] success
[2018-04-02 22:27:22] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:27:31] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:28:30] Device[192.0.0.64] test tftpserver
[2018-04-02 22:28:30] Connect client[192.0.0.64] success
[2018-04-02 22:28:30] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:28:40] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:36:21] TFTP server[192.0.0.128] initialized
[2018-04-02 22:36:56] Device[192.0.0.64] test tftpserver
[2018-04-02 22:36:57] Connect client[192.0.0.64] success
[2018-04-02 22:36:57] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:36:58] Resend required
[2018-04-02 22:37:01] Resend required
[2018-04-02 22:37:02] Resend required
[2018-04-02 22:37:03] Resend required
[2018-04-02 22:37:06] Resend required
[2018-04-02 22:37:20] Resend required
[2018-04-02 22:37:23] Resend required
[2018-04-02 22:37:25] Resend required
[2018-04-02 22:37:26] Resend required
[2018-04-02 22:37:31] Resend required
[2018-04-02 22:37:32] Completed file[C:\tftp\digicap.dav] transmit
[2018-04-02 22:38:31] Device[192.0.0.64] test tftpserver
[2018-04-02 22:38:31] Connect client[192.0.0.64] success
[2018-04-02 22:38:31] Start file[C:\tftp\digicap.dav] transmitting
[2018-04-02 22:38:42] Completed file[C:\tftp\digicap.dav] transmit Добавлено (02.04.2018, 20:36) --------------------------------------------- Первоначально испортил все прошивкой NVR_K41_BL_ML_STD_V3.4.96_170921, а после пытаюсь исправить DS-76xx_77xx_86xxNI-Ex 2015.06.16 V3.3.4 build 150616 и DS-76xx_77xx_86xxNI-Ex 2015.05.22 V3.3.2 build 150522
iTuneDVR | Дата: Вторник, 03.04.2018, 12:37 | Сообщение # 2 |
| Интересно как прошил не той прошивкой?
VladKo | Дата: Вторник, 03.04.2018, 12:48 | Сообщение # 3 |
| iTuneDVR, через web интерфейс зашел на регистратор, выбрал не ту прошивку, и прошил
iTuneDVR | Дата: Вторник, 03.04.2018, 14:46 | Сообщение # 4 |
| Цитата VladKo ( ) iTuneDVR, через web интерфейс зашел на регистратор, выбрал не ту прошивку, и прошил Не той прошивкой не прошить, ни через веб, ни через TFTP В процессе прошивки могло что-то случиться невообразимое, но не той не прошить
VladKo | Дата: Вторник, 03.04.2018, 16:57 | Сообщение # 5 |
| iTuneDVR, DS-7600NI-E1(E2) 7700NI-E4 » V3.4.96 build170921 вот эту залил, и он после заливки стал 15 раз пищать и перезагружаться
iTuneDVR | Дата: Среда, 04.04.2018, 00:19 | Сообщение # 6 |
| Сколько лет аппарату и какая была вначале?
VladKo | Дата: Среда, 04.04.2018, 06:53 | Сообщение # 7 |
| iTuneDVR, можно как то определить старую прошивку по наклейке? Продавца с китая уже нет.
Сообщение отредактировал VladKo - Среда, 04.04.2018, 06:55 |
iTuneDVR | Дата: Среда, 04.04.2018, 12:38 | Сообщение # 8 |
| Цитата VladKo ( ) можно как то определить старую прошивку по наклейке? Продавца с китая уже нет. Умер что-ли?
С этого надо начинать было, что регистратор чинаец. Снимай дамп.
Если рег старый был, старой версии, то максимум апгрейда - до 3.3.4. Если рег был софтово пропатчен, то только поэтому и могла влилась европейская прошивка, но поняв реальное окружение истошно орёт
VladKo | Дата: Среда, 04.04.2018, 19:47 | Сообщение # 9 |
| iTuneDVR, Китаец не умер, магазина его уже нет. То что чинаец, так я написал в группе китайское все, сорян если не прав. Подскажите как дамп снять? п.с. есть конвертер CP2102 если он както может помочьДобавлено (04.04.2018, 19:45) ---------------------------------------------
Добавлено (04.04.2018, 19:47) --------------------------------------------- Слева от 3х конденсаторов разъем ttl я так понял, а как понять распиновку?
VladKo | Дата: Среда, 04.04.2018, 21:04 | Сообщение # 10 |
| 1- GRD 2- RXD 3-TXD 4- не используется Верно?Добавлено (04.04.2018, 20:03) --------------------------------------------- Осталось найти дельную инструкцию Добавлено (04.04.2018, 21:04) --------------------------------------------- Не дождался я ответов)) Методом догадок подключил все через ttl и программы Putty. Выкладываю логи:
Цитата U-Boot 2010.06-svn (May 26 2014 - 10:36:35)
Hit ctrl+u to stop autoboot: 0 ### CRAMFS load complete: 3183432 bytes loaded to 0x80400000 timeout wait for link failed! PHY not link! MAC: C0-56-E3-1B-7D-A7 TFTP server auto connect disabled ## Booting kernel from Legacy Image at 80400000 ... Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel. init started: BusyBox v1.16.1 (2016-06-29 13:49:45 CST) Starting udev: [ OK ] Sat Jan 3 00:44:54 UTC 1970 ----------<1> tar guir webs ---------- ----------<2> show logo ---------- show logo Sat Jan 3 00:45:03 UTC 1970 mv: can't rename '/home/app/exec/pppd': No such file or directory mv: can't rename '/home/app/exec/pppoe': No such file or directory mv: can't rename '/home/app/exec/ss': No such file or directory mv: can't rename '/home/app/exec/dropbear': No such file or directory mv: can't rename '/home/app/exec/dropbearkey': No such file or directory /home/start.sh: line 29: dropbearkey: not found chmod: /usr/bin/dvrCmd/dvrtools: No such file or directory ----------<3> load hisi sdk ---------- The system mem size is 0x1 / load 3535 ok ----------<4> del no use res ---------- mv: can't rename '/home/app/res/adAudio.jpg': No such file or directory /home/start.sh: line 79: ./pppoed: not found iSCSI daemon with pid=911 started!!!! the device is not toe !!!
BusyBox v1.16.1 (2016-06-29 13:49:45 CST) built-in shell (ash) Enter 'help' for a list of built-in commands.
BusyBox v1.2.1 Protect Shell (psh) Enter 'help' for a list of davinci system commands.
# DDR cpld.sys.bits.ddr_bitw : 1 fun:hisi_3535_get_dev_hard_info, line:2354 ***************** no alarm board**************** !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! ^C!!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device buy in cn, you firmware is en err!!!!!!
Starting kernel ...
Uncompressing Linux... done, booting the kernel. init started: BusyBox v1.16.1 (2016-06-29 13:49:45 CST) Starting udev: [ OK ] Sat Jan 3 00:45:56 UTC 1970 ----------<1> tar guir webs ---------- ----------<2> show logo ---------- show logo Sat Jan 3 00:46:05 UTC 1970 mv: can't rename '/home/app/exec/pppd': No such file or directory mv: can't rename '/home/app/exec/pppoe': No such file or directory mv: can't rename '/home/app/exec/ss': No such file or directory mv: can't rename '/home/app/exec/dropbear': No such file or directory mv: can't rename '/home/app/exec/dropbearkey': No such file or directory /home/start.sh: line 29: dropbearkey: not found chmod: /usr/bin/dvrCmd/dvrtools: No such file or directory ----------<3> load hisi sdk ---------- The system mem size is 0x1 / load 3535 ok ----------<4> del no use res ---------- mv: can't rename '/home/app/res/adAudio.jpg': No such file or directory /home/start.sh: line 79: ./pppoed: not found iSCSI daemon with pid=908 started!!!! the device is not toe !!!
# DDR cpld.sys.bits.ddr_bitw : 1 fun:hisi_3535_get_dev_hard_info, line:2354 ***************** no alarm board**************** !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device is illegal, Please call factory!!!!!! !!!!!!!you Device buy in cn, you firmware is en err!!!!!!
Starting kernel ...
Uncompressing Linux... done, booting the kernel. init started: BusyBox v1.16.1 (2016-06-29 13:49:45 CST) Starting udev: [ OK ] Sat Jan 3 00:46:58 UTC 1970 ----------<1> tar guir webs ---------- н\----------<2> show logo ---------- show logo Sat Jan 3 00:47:07 UTC 1970 mv: can't rename '/home/app/exec/pppd': No such file or directory mv: can't rename '/home/app/exec/pppoe': No such file or directory mv: can't rename '/home/app/exec/ss': No such file or directory mv: can't rename '/home/app/exec/dropbear': No such file or directory mv: can't rename '/home/app/exec/dropbearkey': No such file or directory /home/start.sh: line 29: dropbearkey: not found chmod: /usr/bin/dvrCmd/dvrtools: No such file or directory ----------<3> load hisi sdk ---------- The system mem size is 0x1 / load 3535 ok ----------<4> del no use res ---------- mv: can't rename '/home/app/res/adAudio.jpg': No such file or directory /home/start.sh: line 79: ./pppoed: not found iSCSI daemon with pid=908 started!!!! the device is not toe !!!
This program will upgrade software. ******************************************************* * ATTENTION!! PLEASE READ THIS NOTICE CAREFULLY! * * Don't reset machine,or anything that interrupt it. * * The upgrade process must finish in 10 minutes! * * If this program fails,machine might be unusable, * * and you will need to reflash again. * * If you find this too risky,power off machine now. * *******************************************************
Now press [u/U] key to upgrade software: u
Now press [u/U] key to upgrade software: u File system error,please upgrade by TFTP
Please input ip address of device: 192.0.0.64 Please input ip address of upgrade server: 192.0.0.128 Confirm?(y/n): y timeout for link [4999]! MAC: C0-56-E3-1B-7D-A7 TFTP from server 192.0.0.128; our IP address is 192.0.0.64 Download Filename 'digicap.dav'. Download to address: 0x80008000 Downloading: # [ Connected ] ################################ [ 1.000 MB] ################################ [ 2.000 MB] ######################T #########T # [ 3.000 MB] #####################T ########### [ 4.000 MB] ################################ [ 5.000 MB] ####T ############################ [ 6.000 MB] ###############T ################# [ 7.000 MB] ########################T ######## [ 8.000 MB] ################################ [ 9.000 MB] ################################ [10.000 MB] #########################T ####### [11.000 MB] ################################ [12.000 MB] ################################ [13.000 MB] ################################ [14.000 MB] ###########T ##################### [15.000 MB] ###### done Bytes transferred = 15942144 (f34200 hex) digicap.dav match error Language mismatch: In bootparams is 0x2 but in digicap is 0x1
Please input ip address of device: Please input ip address of upgrade server: done Confirm?(y/n): Bytes tran421gicap.dav h e
Please input ip address of device: Language at0x1 Please input ip address of upgrade server: Confirm?(y/n): done Как снять дамп, вопрос в силе)) Как я понял у меня не та прошивка))
iTuneDVR | Дата: Четверг, 05.04.2018, 01:05 | Сообщение # 11 |
| Цитата VladKo ( ) Bytes transferred = 15942144 (f34200 hex) digicap.dav match error Language mismatch: In bootparams is 0x2 but in digicap is 0x1 Ключевая информация!!! Устройство чисто чинайское, а прошивка европейская
VladKo | Дата: Четверг, 05.04.2018, 07:01 | Сообщение # 12 |
| Где взять чинайскую прошивку?
iTuneDVR | Дата: Четверг, 05.04.2018, 14:41 | Сообщение # 13 |
| У чинайцев на чинайском хике, в интернете есть ссылки, были как минимум.
VladKo | Дата: Четверг, 05.04.2018, 20:51 | Сообщение # 14 |
| Короче нашел вроде китайски сайт этот, скачал там прошивку для DS-78 79N-EX прошивка - NVR_K41_QD_CN_STD_V3.4.98_171121, все прошилось рег начал загружаться но теперь на китайском языке, дошел до настрое по картинкам, языка англ нет. Но как я понял англ заблокирован? Каким способом можно разлочить?
iTuneDVR | Дата: Четверг, 05.04.2018, 21:11 | Сообщение # 15 |
| Прошивка для внутреннего рынка, как и устройство, а зачем чинайцам английский, когда у них свой есть родной
avalist | Дата: Четверг, 05.04.2018, 23:50 | Сообщение # 16 |
| Цитата VladKo ( ) Но как я понял англ заблокирован? Каким способом можно разлочить? А посмотрите в web морде есть выбор языка? У меня на китайском был и на английском. Все локальное меню, только китайский. Так и пользовались через браузер, хоть понятно было. Прошивка тоже с китайского сайта hik, восстанавливал аппарат который клиент привез с ali и случайно обновил международной версией. Вроде был DS-71xx какой-то.
iTuneDVR | Дата: Пятница, 06.04.2018, 13:22 | Сообщение # 17 |
| Прошивка была патченная, потому аппарат и работал и принял европейскую прошивку.
VladKo | Дата: Понедельник, 09.04.2018, 20:37 | Сообщение # 18 |
| Цитата avalist ( ) А посмотрите в web морде есть выбор языка? нет нету((Цитата iTuneDVR ( ) Прошивка была патченная Как пропатчить? Дайте совет пожалуйста.
Aleksandr398 | Дата: Среда, 19.06.2019, 23:57 | Сообщение # 19 |
| подскажите как прошить регистратор заново, Регистратор китаец прошил с официального сайта, теперь пищит 15 раз и перезагружается Добавлено (20.06.2019, 00:25) ---------------------------------------------
Цитата VladKo ( ) 1- GRD2- RXD 3-TXD 4- не используется Верно? Добавлено (04.04.2018, 20:03) --------------------------------------------- Осталось найти дельную инструкцию
Добавлено (04.04.2018, 21:04) Дошел до этой стадииДобавлено (20.06.2019, 12:58) --------------------------------------------- U-Boot 2010.06-svn (Aug 15 2015 - 15:18:43)
Protected at offset:0,size:20000 Protection status:[0xf88]=>[0xf8b]. Hit ctrl+u to stop autoboot: 0 ### CRAMFS load complete: 3187728 bytes loaded to 0x80400000 timeout for link [4999]! ## Booting kernel from Legacy Image at 80400000 ... Loading Kernel Image ... OK OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel. init started: BusyBox v1.16.1 (2016-06-29 13:49:45 CST) Starting udev: [ OK ] Mon Mar 9 17:09:04 UTC 1970 ----------<1> tar guir webs ---------- ----------<2> show logo ---------- show logo Mon Mar 9 17:09:14 UTC 1970 mv: can't rename '/home/app/exec/pppd': No such file or directory mv: can't rename '/home/app/exec/pppoe': No such file or directory mv: can't rename '/home/app/exec/ss': No such file or directory mv: can't rename '/home/app/exec/dropbear': No such file or directory mv: can't rename '/home/app/exec/dropbearkey': No such file or directory /home/start.sh: line 29: dropbearkey: not found chmod: /usr/bin/dvrCmd/dvrtools: No such file or directory ----------<3> load hisi sdk ---------- The system mem size is 0x1 / load 3535 ok ----------<4> del no use res ---------- mv: can't rename '/home/app/res/adAudio.jpg': No such file or directory /home/start.sh: line 79: ./pppoed: not found iSCSI daemon with pid=912 started!!!! the device is not toe !!!
iTuneDVR | Дата: Четверг, 20.06.2019, 20:45 | Сообщение # 20 |
| Регистратор был чистый чинаец с патченной софтово прошивкой. Вот он и хочет чисто чинайскую прошивку либо патченный вариант.
Aleksandr398 | Дата: Суббота, 29.06.2019, 20:05 | Сообщение # 21 |
| Цитата iTuneDVR ( ) Регистратор был чистый чинаец с патченной софтово прошивкой.Вот он и хочет чисто чинайскую прошивку либо патченный вариант. а где скачать прошивку можно
iTuneDVR | Дата: Суббота, 29.06.2019, 20:23 | Сообщение # 22 |
| Спросить у продавца, если он добрый и вышлет.
Aleksandr398 | Дата: Суббота, 29.06.2019, 22:41 | Сообщение # 23 |
| Цитата iTuneDVR ( ) Спросить у продавца, если он добрый и вышлет. Продавца контактов нет и регистратору сто лет в обед, подскажи где качнуть
Oleglevsha | Дата: Суббота, 29.06.2019, 22:47 | Сообщение # 24 |
| Цитата Aleksandr398 ( ) !!!!!!!you Device is illegal, Please call factory!!!!!! Ремонт видеорегистраторов и видеокамер из поднебесной возможен в славном городе Волгоград...
Aleksandr398 | Дата: Суббота, 29.06.2019, 22:49 | Сообщение # 25 |
| Цитата Oleglevsha ( ) Ремонт видеорегистраторов и видеокамер из поднебесной возможен в славном городе Волгоград... Прошивка нужна китайская не подскажешь где качнуть. Рег галимый китайДобавлено (29.06.2019, 22:55) --------------------------------------------- U-Boot 2010.06-svn (Aug 15 2015 - 15:18:43)
Please input ip address of device: 192.0.0.64 Please input ip address of upgrade server: 192.0.0.128 Confirm?(y/n): y timeout for link [4999]! MAC: BC-AD-28-E5-15-F0 TFTP from server 192.0.0.128; our IP address is 192.0.0.64 Download Filename 'digicap.dav'. Download to address: 0x80008000 Downloading: # [ Connected ] ################################ [ 1.000 MB] ################################ [ 2.000 MB] ################################ [ 3.000 MB] ################################ [ 4.000 MB] ################################ [ 5.000 MB] ################################ [ 6.000 MB] ################################ [ 7.000 MB] ################################ [ 8.000 MB] ################################ [ 9.000 MB] ################################ [10.000 MB] ################################ [11.000 MB] ################################ [12.000 MB] ################################ [13.000 MB] ################################ [14.000 MB] ################################ [15.000 MB] ################### done Bytes transferred = 16351813 (f98245 hex) digicap.dav match error Language mismatch: In bootparams is 0x2 but in digicap is 0x1
Please input ip address of device: Прошивка не подходит
Oleglevsha | Дата: Воскресенье, 30.06.2019, 07:58 | Сообщение # 26 |
| На китайском сайте Hikvision http://www1.hikvision.com/cn/download_more_699.html#prettyPhoto
Aleksandr398 | Дата: Суббота, 06.07.2019, 13:13 | Сообщение # 27 |
| Цитата Oleglevsha ( ) На китайском сайте Hikvisionhttp://www1.hikvision.com/cn/download_more_699.html#prettyPhoto
СпасибоДобавлено (08.07.2019, 14:15) ---------------------------------------------
Цитата VladKo ( ) Короче нашел вроде китайски сайт этот, скачал там прошивку для DS-78 79N-EX прошивка - NVR_K41_QD_CN_STD_V3.4.98_171121, все прошилось рег начал загружаться но теперь на китайском языке, дошел до настрое по картинкам, языка англ нет. Но как я понял англ заблокирован? Каким способом можно разлочить? Подскажите где можно найти прошивку или что можно сделать?
Oleglevsha | Дата: Понедельник, 08.07.2019, 21:14 | Сообщение # 28 |
| Я могу исправить, пришлите в Волгоград, стоимость 1500р + почтовые расходы
Aleksandr398 | Дата: Понедельник, 08.07.2019, 21:26 | Сообщение # 29 |
| Цитата Oleglevsha ( ) Я могу исправить, пришлите в Волгоград, стоимость 1500р + почтовые расходы Если б жил поблизости то без проблем, а так дешевле новый купить, либо договориться сколько прошивка стоить будет если скинете на почту
Oleglevsha | Дата: Понедельник, 08.07.2019, 21:40 | Сообщение # 30 |
| Ремонт производится только при условии наличия девайса у меня в мастерской, Поищите сервисный центр в своем регионе...
Aleksandr398 | Дата: Среда, 10.07.2019, 22:39 | Сообщение # 31 |
| Помогите пропатчить китайскую прошиву на русский или английский
iTuneDVR | Дата: Четверг, 11.07.2019, 14:09 | Сообщение # 32 |
| Цитата Aleksandr398 ( ) Помогите пропатчить китайскую прошиву на русский или английский Выше предложено решение вопроса или запрос на научить?
Aleksandr398 | Дата: Пятница, 12.07.2019, 21:07 | Сообщение # 33 |
| Цитата iTuneDVR ( ) Выше предложено решение вопроса или запрос на научить? помочь
iTuneDVR | Дата: Суббота, 13.07.2019, 00:51 | Сообщение # 34 |
| Цитата Aleksandr398 ( ) а так дешевле новый купить,
Продай этот как есть, купи другой правильный.
Сообщение отредактировал iTuneDVR - Суббота, 13.07.2019, 00:51 |
cahek127 | Дата: Вторник, 08.10.2019, 12:12 | Сообщение # 35 |
| добрый день, есть регистратор ds 7604n-e1/4p китаец, был случайно прошит европейской прошивкой. при включении теперь пищит 15 раз и перегружается. через tftp не шьется китайской прошивкой, хотя пингуется. в tftp висит строка [2019-10-07 13:20:03] TFTP server[192.0.0.128] initialized и все, подскажите как вернуть к жизни регик)
Сообщение отредактировал cahek127 - Вторник, 08.10.2019, 12:58 |
iTuneDVR | Дата: Вторник, 08.10.2019, 23:21 | Сообщение # 36 |
| Прошить оригинальной чинайской прошивкой с чинайского сайта
cahek127 | Дата: Среда, 09.10.2019, 07:23 | Сообщение # 37 |
| Цитата iTuneDVR ( ) Прошить оригинальной чинайской прошивкой с чинайского сайта
а как? через tftp не получается, висит на этом TFTP server[192.0.0.128] initialized и все
на регике пишется embedded nvr
Сообщение отредактировал cahek127 - Среда, 09.10.2019, 07:43 |
iTuneDVR | Дата: Среда, 09.10.2019, 21:40 | Сообщение # 38 |
| Подключиться к TTL разъему адаптером и оттуда.
cahek127 | Дата: Четверг, 17.10.2019, 20:15 | Сообщение # 39 |
| Подскажите нету не у кого прошивки для китайцев с русским языком?? Может кто нашел поделитесь пожалуйста Добавлено (18.10.2019, 15:19) --------------------------------------------- Подскажите знающие, если я куплю регистратор у официалов он не увидит мои китайские камеры, я правильно понимаю? На алике продают регистраторы типо английскую версию и поддерживающие обновление прошивок - это тоже развод или что то поменялось ??? Добавлено (18.10.2019, 15:24) --------------------------------------------- https://ru.aliexpress.com/item....48998.2
iTuneDVR | Дата: Пятница, 18.10.2019, 19:31 | Сообщение # 40 |
| Не совсем развод, но может быть, что конкретное устройство с пропатченной прошивкой и оно работает как европеец.
