Данный сайт является проектом ООО "Амакс". Сегодня: Среда, 05.02.2025, 16:55
DS-2CD2042WD-I прошивка через tftp
den23rusДата: Понедельник, 10.08.2020, 20:05 | Сообщение # 1
Пробовал все прошивки с версии R6, кидаю логи после прошивки на эту: IPC_R6_EN_STD_5.5.5_180111
Лог прошивки:
U-Boot 3.1.6-195297 (May 25 2016-11:39:03)
boards:195277
Boot From: NAND 2048 RC
SYS_CONFIG: 0x30060059 POC: 100
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2042WD-I
Hit Ctrl+u to stop autoboot: 2
Hit Ctrl+u to stop autoboot: 1
Formatting .................................................................................................................................................................................................................. done!
[ INFO][MIN]TFTP: TFTP from server 192.0.0.128
[ INFO][MIN]TFTP: Filename: 'digicap.dav'
[ INFO][MIN]TFTP: ################################################################################
[ INFO][MIN]TFTP: Download File
[OK][ INFO][MIN]BURN: File size is 32157465 bytes (31403 KB)
[ INFO][MIN]BURN: Writing Flash
[ INFO][MIN]BURN: ..............................................................................................................
[ INFO][MIN]BURN: Write Flash
[OK]***** UPDATE COMPLETE *****
BusyBox v1.2.1 Protect Shell (psh)
Help:
# help
Support Commands:
taskShow                printPart                prtHardInfo
getPreviewStatus        setIp                    setV6ip
setGateway              dspStatus                outputClose
outputOpen              getDebug                setDebug
debugLog                getIrstate              getMtu
camCmd                  getCamVer                getIrstate
getLux                  getMcuInfo              getMotion
getRawdata              setIrcmd                setRectFrame
updateCamera            setLaserMode            getLaserMode
setIrMode                getIrMode                setBaiguangMode
getBaiguangMode          setYTLock                InquireFanSwitch
StartLaser              CloseLaser              LaserMotReset
EnlargeCur              ReduceCur                SetCur
LaserMotDirect          LaserTeleOffset          LaserWideOffset
InqSwitch                InqCurrent              InqCurMotDirect
getMcuStateInfo          setFastFocus            getTrackStatus
getSelfcheckResult      setLdcMode              getLdcMode
getPreviewStatus        appCmd                  camCmd
ezoomlens_start_t2_test prtLensCurve            getLensCurve
getIp                    gdbcfg                  {Test1}
{Test2}                  {Test3}                  {Test4}
{TestN}                  {TestY}                  getIsp
getISP                  getisp                  setIsp
setISP                  setisp                  regread
regwrite                setAgingMode            getAgingMode
setAgingTime            getAgingTime            setLensZoomPos
getLensZoomPos          dm365                    ss
showKey                  showServer              showUpnp
showStatus              showDefence              setLBS
setAlarm                cloudService            t1
ifconfig                netstat                  ping
ping6                    top                      iostat
mpstat                  ps                      reset
dmesg                    exit                    getDateInfo
diagnose                help
Лог после прошивки:
boards:195277
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
|RCV UDP pack timeout|
cmd 'null' is not supported.
nand booting ...
booting from pri part...
load kernel...
init started: BusyBox v1.19.3 (2017-12-28 10:16:53 CST)
starting pid 46, tty '': '/etc/init.d/rcS'
Starting udev:      [ OK ]
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
diagnose_way = 15, repair_way = 1, interval = 60
route: ioctl 0x890c failed: No such process
Default method to init without VIN drivers...
Cat this file to find out what VIN can be supported.
Default init without lens driver
Use default settings
/home/script/init.sh: line 553: which: not found
[   18.903823] [ kernel version:  svn-321291 ]
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x76a7e000
loading /home/firmware/orccode.bin...addr = 0x76a7e000, size = 0x171cca
loading /home/firmware/orcme.bin...addr = 0x76d7e000, size = 0x51644
loading /home/firmware/default_binary.bin...addr = 0x76e1e000, size = 0x40000
ucode (S2L) version = 2017/5/25 271820.271498
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus   0 .
Enter DB_main-------------------
shared memory address is: 0x76c37000, sizeof(DEVICECONFIG) = 959848
netprocess Infomation:
version: 5.10.2 [20:30:33-Jul 18 2017]
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 299284
Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017)
wait davinci set default...
[08-10 20:02:12][pid:570][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[08-10 20:02:12][pid:577][IPC] [ERROR]from daemon ack, dst not work  len 0 , load_type is [0x10012]
[08-10 20:02:12][pid:577][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[08-10 20:02:12][pid:577][UNI_IF][ERROR]communicaite_to_davinci failed!!!
copy default.cls ok.
[08-10 20:02:13][pid:570][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[08-10 20:02:13][pid:577][IPC] [ERROR]from daemon ack, dst not work  len 0 , load_type is [0x10012]
[08-10 20:02:13][pid:577][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[08-10 20:02:13][pid:577][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[08-10 20:02:14][pid:570][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[08-10 20:02:14][pid:577][IPC] [ERROR]from daemon ack, dst not work  len 0 , load_type is [0x10012]
[08-10 20:02:14][pid:577][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[08-10 20:02:14][pid:577][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus  End
shared memory address is: 0x769e8000, sizeof(DEV_CAPABILITY) = 258664
[08-10 20:02:14][pid:591][HW_IF][ERROR]ioctl error errno=5
[08-10 20:02:14][pid:591][SYSINIT][ERROR]hwif_getsecinfo failed.
[08-10 20:02:14][pid:591][SYSINIT][ERROR]sys app init failed to reboot!
[08-10 20:02:15][pid:570][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[08-10 20:02:15][pid:577][IPC] [ERROR]from daemon ack, dst not work  len 0 , load_type is [0x10012]
[08-10 20:02:15][pid:577][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[08-10 20:02:15][pid:577][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[08-10 20:02:16][pid:570][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[08-10 20:02:16][pid:577][IPC] [ERROR]from daemon ack, dst not work  len 0 , load_type is [0x10012]
[08-10 20:02:16][pid:577][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[08-10 20:02:16][pid:577][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[   29.627547] Restarting system.
