aavan | Дата: Понедельник, 08.02.2021, 02:25 | Сообщение # 1 |
| Доброго всем!Отказали сразу 2 камеры DS-2CD2442FWD-IW.Пропали из сети и на лицевой стороне загорелись все светодиоды.SADP не видит.Кнопка rst. не помогла.на шильдике sv 5.5.0_170725.на сервере хиквижна нашел такую,но обновляться через tftp камера не стала.подключил uart:
help & printenv
U-Boot 3.1.6-269644 (Jul 6 2017-10:47:55) boards:296717 Boot From: NAND 2048 RC
SYS_CONFIG: 0x3006005B POC: 101
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2442FWD-IW Hit Ctrl+u to stop autoboot: 2
HKVS # help
The following commands are supported:
boot erase help reset
setenv printenv saveenv updateb
upf update format go
mii gpio ping
Use 'help' to get help on a specific command
HKVS # printenv
ipaddr=192.0.0.64
serverip=192.0.0.128
gatewayip=0.0.0.0
netmask=255.255.255.0
ethaddr=b4:a3:82:5b:f8:17
loadaddr=0x00208000
bootfile=hImage
bootcmd=null
bootargs=console=ttyS0
bootdelay=2
HKVS #
log:
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2442FWD-IW Hit Ctrl+u to stop autoboot: 2 Hit Ctrl+u to stop autoboot: 1 Hit Ctrl+u to stop autoboot: 0
|NUL eth|
cmd 'null' is not supported.
nand booting ...
booting from pri part... load kernel...
init started: BusyBox v1.19.3 (2017-07-20 11:10:26 CST)
starting pid 46, tty '': '/etc/init.d/rcS' Starting udev: [ OK ] UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi1_0. waiting for /dev/ubi1_0. pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1 UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi3_0. Check dir /davinci ok! (0) UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) waiting for /dev/ubi4_0. Check dir /config ok! (0) diagnose_way = 15, repair_way = 1, interval = 60 route: ioctl 0x890c failed: No such process Default method to init without VIN drivers... Cat this file to find out what VIN can be supported. Default init without lens driver Use default settings /home/script/init.sh: line 553: which: not found / [ 17.971168] [ kernel version: svn-300837 ] map_size = 0x400000, nr_item = 3 addr_offset = 0x00000000, filename = orccode.bin addr_offset = 0x00300000, filename = orcme.bin addr_offset = 0x003a0000, filename = default_binary.bin mmap returns 0x76ab1000 loading /home/firmware/orccode.bin...addr = 0x76ab1000, size = 0x171cca loading /home/firmware/orcme.bin...addr = 0x76db1000, size = 0x51644 loading /home/firmware/default_binary.bin...addr = 0x76e51000, size = 0x40000 =============================================== ucode (S2L) version = 2017/5/25 271820.271498 =============================================== ln: prtLensCurve: File exists ln: /dev/ttyS1: File exists ln: /bin/t1: File exists cp: can't stat '/dav/libutils.so': No such file or directory chmod: /lib/libutils.so: No such file or directory ln: /dev/rtc: File exists =====check_config start===== ===db file doesn't exist=== ===db file doesn't exist=== ==== both config files are broken==== infd read End Unix bus 0 .
netprocess Infomation: version: 5.10.2 [20:30:33-Jul 18 2017] Path: /Camera/Platform/Trunk/FSP_network_protocol Last Changed Rev: 299284 Last Changed Date: 2017-07-14 17:00:38 +0800 (Fri, 14 Jul 2017) .
Enter DB_main------------------- shared memory address is: 0x76b96000, sizeof(DEVICECONFIG) = 959848 wait davinci set default... [02-06 19:55:00][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [02-06 19:55:00][pid:557] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [02-06 19:55:00][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [02-06 19:55:00][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!! copy default.cls ok. [02-06 19:55:01][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [02-06 19:55:01][pid:557] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [02-06 19:55:01][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [02-06 19:55:01][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!! [02-06 19:55:02][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [02-06 19:55:02][pid:557] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [02-06 19:55:02][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [02-06 19:55:02][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!! Unix bus End shared memory address is: 0x76930000, sizeof(DEV_CAPABILITY) = 258664 [02-06 19:55:02][pid:571][HW_IF][ERROR]ioctl error errno=5 [02-06 19:55:02][pid:571][SYSINIT][ERROR]hwif_getsecinfo failed. [02-06 19:55:02][pid:571][SYSINIT][ERROR]sys app init failed to reboot! [02-06 19:55:03][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [02-06 19:55:03][pid:557] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [02-06 19:55:03][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [02-06 19:55:03][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!! [02-06 19:55:04][pid:550][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1 [02-06 19:55:04][pid:557] [IPC][ERROR]from daemon ack, dst not work len 0 , load_type is [0x10012] [02-06 19:55:04][pid:557][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3. [02-06 19:55:04][pid:557][UNI_IF][ERROR]communicaite_to_davinci failed!!! [ 28.768604] Restarting system. [4l
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model:DS-2CD2442FWD-IW Hit Ctrl+u to stop autoboot:2
и вот что имею после прошивки командой:
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
HKVS # update
'update' is a ambiguous command! Exec the shortest command
[ INFO][MIN]TFTP: TFTP from server 192.0.0.128 [ INFO][MIN]TFTP: Filename: 'digicap.dav' [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ###################################################### [ INFO][MIN]TFTP: Download File [OK][ INFO][MIN]BURN: File size is 32106942 bytes (31354 KB) [ INFO][MIN]BURN: Writing Flash [ INFO][MIN]BURN: .............................................................................................................. [ INFO][MIN]BURN: Write Flash [OK]***** UPDATE COMPLETE *****
BusyBox v1.2.1 Protect Shell (psh) Enter 'help' for a list of davinci system commands.
# help Support Commands: taskShow printPart prtHardInfo getPreviewStatus setIp setV6ip setGateway dspStatus outputClose outputOpen getDebug setDebug debugLog getIrstate getMtu camCmd getCamVer getIrstate getLux getMcuInfo getMotion getRawdata setIrcmd setRectFrame updateCamera setLaserMode getLaserMode setIrMode getIrMode setBaiguangMode getBaiguangMode setYTLock InquireFanSwitch StartLaser CloseLaser LaserMotReset EnlargeCur ReduceCur SetCur LaserMotDirect LaserTeleOffset LaserWideOffset InqSwitch InqCurrent InqCurMotDirect getMcuStateInfo setFastFocus getTrackStatus getSelfcheckResult setLdcMode getLdcMode getPreviewStatus appCmd camCmd ezoomlens_start_t2_test prtLensCurve getLensCurve getIp gdbcfg {Test1} {Test2} {Test3} {Test4} {TestN} {TestY} getIsp getISP getisp setIsp setISP setisp regread regwrite setAgingMode getAgingMode setAgingTime getAgingTime setLensZoomPos getLensZoomPos dm365 ss showKey showServer showUpnp showStatus showDefence setLBS setAlarm cloudService t1 ifconfig netstat ping ping6 top iostat mpstat ps reset dmesg exit getDateInfo diagnose help # reset
The system is goi Sent SIGKILL to all processes
Requesting system reboot
list of davinci system commands. после перезагрузки не появляется
хотелось бы понять в чем затык и что делать дальше.
по команде upf камера ищет на tftp сервере файл mImage и не найдя сообщает об ощибке
error: upm.(error: tftp.)! update mini system [FAIL]!error: upf. !!!!! UPDATE FAIL !!!!! HKVS # update
[ INFO][MIN]TFTP: TFTP from server 192.0.0.128 [ INFO][MIN]TFTP: Filename: 'digicap.dav' [ INFO][MIN]TFTP: ################################################################################ [ INFO][MIN]TFTP: ### [ INFO][MIN]TFTP: Download File [OK][ INFO][MIN]BURN: File size is 34011619 bytes (33214 KB) [ INFO][MIN]BURN: Writing Flash [ INFO][MIN]BURN: .................................................................................................................. [ INFO][MIN]BURN: Write Flash [OK]***** UPDATE COMPLETE *****
перепробовал практически все прошивки R6.
iTuneDVR | Дата: Понедельник, 08.02.2021, 12:58 | Сообщение # 2 |
| Цитата aavan ( ![Ссылка на цитируемый текст](/.s/img/fr/ic/10/lastpost.gif) ) [02-06 19:55:02][pid:571][SYSINIT][ERROR]hwif_getsecinfo failed. Проблема в этом
aavan | Дата: Понедельник, 08.02.2021, 19:32 | Сообщение # 3 |
| [02-06 19:55:02][pid:571][SYSINIT][ERROR]hwif_getsecinfo failed.Проблема в этом Вау!Да это всё меняет
